POV-Ray : Newsgroups : povray.newusers : Transformation question Server Time
17 Jan 2026 09:46:43 EST (-0500)
  Transformation question (Message 1 to 5 of 5)
Subject: Transformation question
Date: 28 Jan 2005 03:15:16
Message: <41f9f494$1@news.povray.org>
Hallo!
Is possible in POV-Ray perform a topological transformation on the surface
of a generical object in order to make it assuming the conformation of
another generical object?
For example, I have object A (e.g. a house) and I want to give it the
conformation of another object (e.g. a cone).
Thank you in advance,
Paolo
Subject: Re: Transformation question
Date: 28 Jan 2005 03:53:10
Message: <41f9fd76@news.povray.org>
  No.
Date: 28 Jan 2005 04:39:32
Message: <M+wrjBA5gg+BFwNK@econym.demon.co.uk>
Wasn't it Paolo Gibellini who wrote:
>Hallo!
I don't believe you can do it for general objects, but you can
theoretically morph any isosurface into any other isosurface.
#declare F1=function{F_House( ... )}
#declare F_Cone=function(x,y,z,a){x*x+z*z-y*y*a}
#declare F2=function{F_Cone( ... )}
isosurface {
  function { (1-clock)*F1(x,y,z) + clock*F2(x,y,z) }
This technique sometimes causes the first shape to morph away to
nothing, and the second shape to morph into existence from nothing. It's
possible to use tricks to fix this for some cases, but there may not be
a universal solution.
Good luck trying to write the F_House function.
Mike Williams
Gentleman of Leisure
Date: 28 Jan 2005 04:54:54
Message: <41fa0bee$1@news.povray.org>
Thank you,
 I will surely try!
Paolo
Date: 28 Jan 2005 04:56:27
Message: <41fa0c4b$1@news.povray.org>
surface
>   No.
What a pity...
However, thank you!
Paolo
