POV-Ray : Newsgroups : povray.newusers : f_noise3d deterministic Server Time
17 Jan 2026 09:46:19 EST (-0500)
  f_noise3d deterministic (Message 1 to 3 of 3)
Subject: f_noise3d deterministic
Date: 22 Dec 2004 18:56:29
Message: <41ca09ad@news.povray.org>
Folks,
I wanted to create some irregular spheres ... I created two of these using:
isosurface {
   function { f_sphere(x, y, z, 1)-f_noise3d(x, y, z) }
   contained_by { box { <-2,-2,-2>, <2,2,2> } }
this was performed twice.  My problem is that BOTH shapes were identical.  I
had imagined that multiple calls to f_noise3d() would have resulted in
different shapes.
Is this correct?  Any way I can preturb the output of f_noise3d()?
Neil
Subject: Re: f_noise3d deterministic
Date: 22 Dec 2004 19:25:48
Message: <41ca108c@news.povray.org>
> different shapes.
  If f_noise3d() would return different values for the exact same parameters
at each call, it would be pretty much useless. It would be just a random
number generator, which would not be usable at all in isosurfaces.
  Just add a constant to one or more parameters to the function
(ie like f_noise3d(x+10, y+5, z)).
Date: 23 Dec 2004 00:21:51
Message: <41ca55ef$1@news.povray.org>
Thank you my friend.  Just perfect!!
Neil
