POV-Ray : Newsgroups : povray.newusers : How to apply a different imagemap to different sides of a cube Server Time
11 Jul 2026 16:08:56 EDT (-0400)
  How to apply a different imagemap to different sides of a cube (Message 1 to 4 of 4)
Subject: How to apply a different imagemap to different sides of a cube
Date: 3 Dec 2004 21:03:43
Message: <41b11aff$1@news.povray.org>
Folks,
Still a newbie here ...
I have 6 images that I would like to apply to the 6 different faces of a
cube.  Is there I way I can achieve that task?
Neil
Subject: Re: How to apply a different imagemap to different sides of a cube
Date: 3 Dec 2004 22:29:47
Message: <41b12f2b$1@news.povray.org>
Neil Kolban wrote:
> Folks,
> Neil
I posted one solution on p.b.scene-files
It uses handcoded mesh and uv's and a composite image for the image map
Date: 4 Dec 2004 16:45:00
Message: <web.41b22efaf420974d6fa80cd40@news.povray.org>
"Neil Kolban" <kol### [at] kolbancom> wrote:
> Folks,
> Neil
I suppose you could use csg difference to cut off small amounts of your cube
on each face and put a different texture on each face.
For example:
difference
   box{0 1} // no texture needed
   plane{y,0.0001 texture{bottom_face}}
   plane{-y,-0.9999 texture{top_face}}
   plane{x,0.0001 texture{left_face}}
   plane{-x,-0.9999 texture{right_face}}
   plane{z,0.0001 texture{front_face}}
   plane{-z,-0.9999 texture{back_face}}
This code has not been tested, but the following has:
difference
 box{0 1}
 plane{y,0.0001 texture{pigment{rgb<1,0,0>}}}
 plane{-y,-0.9999 texture{pigment{rgb<0,0,1>}}}
 plane{x,0.0001 texture{pigment{rgb<0,1,0>}}}
 plane{-x,-0.9999 texture{pigment{rgb<1,0,1>}}}
 plane{z,0.0001 texture{pigment{rgb<1,1,0>}}}
 plane{-z,-0.9999 texture{pigment{rgb<0,1,1>}}}
Hope this helps!
Nathan Jolly (Captain Chemistry)
Date: 5 Dec 2004 18:24:13
Message: <Xns95B7461785D2raf256com@203.29.75.35>
njj### [at] studentmonasheduau
news:web.41b22efaf420974d6fa80cd40@news.povray.org
> For example:
Wouldnt it be better to combine polygons?
My solution:
#macro BoxTex(A,B, Af,Aw,Ac)
  union {
    polygon { 4
      <A.x,A.y,A.z> <B.x,A.y,A.z>
      <B.x,A.y,B.z> <A.x,A.y,B.z>
      texture { Af rotate x*90 }
    polygon { 4
      <B.x,B.y,A.z> <A.x,B.y,A.z>
      texture { Aw rotate z*90 }
    polygon { 4
      <A.x,A.y,B.z> <B.x,A.y,B.z>
      <B.x,B.y,B.z> <A.x,B.y,B.z>
    polygon { 4
      <A.x,A.y,A.z> <A.x,B.y,A.z>
      <A.x,B.y,B.z> <A.x,A.y,B.z>
      texture { Aw rotate y*90 }
    polygon { 4
      <B.x,A.y,A.z> <B.x,B.y,A.z>
      <B.x,B.y,B.z> <B.x,A.y,B.z>
    polygon { 4
      <A.x,B.y,A.z> <B.x,B.y,A.z>
      texture { Ac rotate x*90 }
    //  scale 0.10
Call it usign two vectors, and three textures - for floor, walls and
celing.
It is neede to:
  A.x < B.x
  A.y < B.y
  A.z < B.z
btw, povray complains about not closed polygon, how to fix it (just add 5-
th point?)
http://www.raf256.com/3d/
Computer Graphics
