POV-Ray : Newsgroups : povray.newusers : Co-planar polygons Server Time
20 Nov 2025 09:32:54 EST (-0500)
  Co-planar polygons (Message 1 to 5 of 5)
Subject: Co-planar polygons
Date: 19 Nov 2004 18:32:15
Message: <419e827f$1@news.povray.org>
I'm creating a polygon object and getting a strange error on it.
polygon {
   5
   <.7,-1.1,.5>,
   <-.6,-1,.4>,
   <-.3,-1,-.4>,
   <-.4,-1.1,-.5>,
   <.7,-1.1,.5>
The file renders, but that poly doesn't show and I get the following
error: "Parse Warning: Points in polygon are not co-planar. Ignoring
plygons." Several other polys using some of the same points render just
fine.
What am I doing wrong??
~Mike
Subject: Re: Co-planar polygons
Date: 19 Nov 2004 18:35:11
Message: <419e832f@news.povray.org>
Do all these points lie on the surface of *one* plane? I doubt it, just by
the look of the values spread around. If you use just three points, it
always works, as three points always create a plane, but a fourth one might
make some trouble. Maybe you've just had luck with the combination for other
polygons.
Tim
"Tim Nikias v2.0"
Date: 19 Nov 2004 21:20:52
Message: <419eaa04$1@news.povray.org>
> polygons.
A quick top-down view check reveals that you hit it spot on. I never
would have even thought of checking that. And even once I knew that's
what the problem was, it was trial-and-error to fix it!
Thanks a bunch!
~Mike
Date: 20 Nov 2004 01:22:17
Message: <kurtzlepirate-340B66.07221720112004@news.povray.org>
In article <419e827f$1@news.povray.org>,
>>polygon {
>>   5
>>   <.7,-1.1,.5>,
>>   <-.6,-1,.4>,
>>   <-.3,-1,-.4>,
>>   <-.4,-1.1,-.5>,
>>   <.7,-1.1,.5>
>>fine.
>>~Mike
  strange... points for polygon are defined with x and y coord. only !
  take a look at http://www.povray.org/documentation/view/3.6.1/294/
  and http://www.povray.org/documentation/view/3.6.1/69/
  klp
Date: 20 Nov 2004 03:34:35
Message: <MPG.1c091ff04a77537f989692@news.povray.org>
kurtz le pirate wrote:..
> >>polygon {
> >>   5
> >>   <.7,-1.1,.5>,
> >>   <-.6,-1,.4>,
> >>   <-.3,-1,-.4>,
> >>   <-.4,-1.1,-.5>,
> >>   <.7,-1.1,.5>
> >>fine.
> >>~Mike
>   klp
From the documentation:
" All points of a polygon are three-dimensional vectors that have to lay
on the same plane. If this is not the case an error occurs. It is common
to use two-dimensional vectors to describe the polygon. POV-Ray assumes
that the z value is zero in this case."
Nevertheless, I think you can use 3D coordinates to define the points.
It's already a long time ago I met the same problems using the
coordinates of the vertices for pentagons that are the faces of a
dodecahedron. I remember it's a question of some "tolerance" Povray uses
to see if the given points are coplanar. The method I prefered consisted
in declaring a pentagon as the union of three triangles.
Some of the images can be seen on the pages devoted to polyhedra on my
site.
Herman
home page: http://cage.ugent.be/~hs
