POV-Ray : Newsgroups : povray.newusers : Trying to figure out media... Server Time
10 Apr 2026 14:27:29 EDT (-0400)
  Trying to figure out media... (Message 1 to 3 of 3)
Subject: Trying to figure out media...
Date: 2 Nov 2004 00:34:55
Message: <41871c7f@news.povray.org>
...through some confusing methods...
Im trying to model a bubble full of semi-transparant, absorbing and
filtering/transmitting media; inside a (as of yet invisible) container
full of maybe murky water.
What I think I cant figure out, is how to properly create and light the
boudary between the air of the bubbles, and the water. Or maybe the film
of the water on top of air? I know its similar to looking up through the
surface of the water, but I havnt been able to achieve the full effect.
I've spent a lot of time in the water, and its hard to apply the
technique in POVray, to what I think is actually happening (having
briefly looked into the effect, and its properties).
heres the source, im trying to find a place to put them on the web,
since i havnt fully mastered news groups yet, this might take a few mins...
thanks for any help.
Drey.
#version 3.6;
//#version unofficial megapov 1.1;
global_settings {  assumed_gamma 1.0
                    noise_generator 2
                    max_trace_level 5
#include "functions.inc"
#include "bubble.inc"
   //location  <-1,1.8,-3.5>
   location <0,2.5,7>
   look_at   <1,0,0>
   rotate 35*y
// sun ---------------------------------------------------------------------
light_source{< -3000, 3000, -3000> color White}
// sky ---------------------------------------------------------------------
sky_sphere { pigment { gradient <0,1,0>
                        color_map { [0.00 rgb <0.6,0.7,1.0>]
                                    [0.35 rgb <0.0,0.1,0.8>]
                                    [0.65 rgb <0.0,0.1,0.8>]
                                    [1.00 rgb <0.6,0.7,1.0>]
                        scale 2
/*#macro Axis_( AxisLen, RedTexture,WhiteTexture)
union{
     cylinder {<0,-AxisLen,0>,<0,AxisLen,0>,0.05
               texture{checker texture{RedTexture}
                               texture{WhiteTexture}
                       translate<0.1,0,0.1>}}
     cone{<0,AxisLen,0>,0.2,<0,AxisLen+0.7,0>,0
          texture{RedTexture}}
      } // end of union
#end // of macro "Axis( )"
#macro AxisXYZ( AxisLenX, AxisLenY, AxisLenZ, TexRed, TexWhite)
//-------------------------- drawing 3 axes --------------------------------
union{
    object{Axis_(AxisLenX, TexRed, TexWhite)   rotate< 0,0,-90>}   // x axis
    object{Axis_(AxisLenY, TexRed, TexWhite)   rotate< 0,0,  0>}   // y
axis
    object{Axis_(AxisLenZ, TexRed, TexWhite)   rotate<90,0,  0>}   // z axis
//---------------------- names of the axes ---------------------------------
    text{ ttf"arial.ttf",  "x",  0.15,  0  texture{TexRed}
          scale 0.5 translate <AxisLenX+0.05,0.4,-0.10>}
    text{ ttf"arial.ttf",  "y",  0.15,  0  texture{TexRed}
          scale 0.5 translate <-0.75,AxisLenY+0.50,-0.00>}
    text{ ttf"arial.ttf",  "z",  0.15,  0  texture{TexRed}
          scale 0.5 translate <-0.75,0.2,AxisLenZ+0.50>}
} // end of union
#end// of macro
object{AxisXYZ (3,3,3,
                 texture{ pigment{rgb<1,0,0>} finish{diffuse 0.8 phong 1}},
                 texture{ pigment{rgb<1,1,1>} finish{diffuse 0.8 phong 1}})
        } // end of axes
// ground ------------------------------------------------------------------
plane {
         y,-1
         material {checkerz}
#declare X=rand(R1)/3;
#declare Y=rand(R1)/3;
#declare Z=rand(R1)/5;
#declare X1=rand(R2)/3;
#declare Y1=rand(R2)/3;
#declare Z1=rand(R2)/5;
#declare X2=rand(R3)/3;
#declare Y2=rand(R3)/3;
#declare Z2=rand(R3)/5;
#declare Media =
media
      emission 1
      density
        { spherical density_map
          { [0.0 rgb 0]
            [0.25 rgb <1,0,0>]
            [0.5 rgb <1,1,0>]
            [0.75 rgb <0,1,0>]
            [1.0 rgb <0,1,1>]
            [1.25 rgb <0,0,1>]
#declare Media1 =
media
         scattering {1}
         //aa_level     : 4
         //aa_threshold : 0.1
         //absorption   : <0,0,0>
         //confidence   : 0.9
         //emission     : <0,0,0>
         //intervals    : 10
         //method       : 3
         //ratio        : 0.9
         //samples      : Min 1, Max 1
         //variance     : 1/128
         //SCATTERING
         //        COLOR        : <0,0,0>
         //        eccentricity : 0.0
         //        extinction   : 1.0
#declare water =
material
    {texture{pigment{color rgbf <0.9, 0.9, 1.0, 0.9>}
          /*finish
                 ambient 0.1
                 phong 1.0
                 phong_size 100.0
                 reflection 0.4
       interior
                 ior 1.33
//box{<-2,-1,-1><2,1,-1.5> scale 2 }
difference {
box {<-2,-1,-1><2,1,1>
      material {water}
isosurface
         {                    //Experiment
         function {f_sphere(x, y, z, .9)+f_noise3d(x+X, y+Y, z+Z)}
         contained_by {sphere {< 0, 0, 0>, 1}}
         max_trace 4
         max_gradient 1.6
         material
                 texture
                         pigment {color rgbf <0,0,0,0,1>}
                         //finish { diffuse 0.2 specular 0.6 }
         interior
                 media
                         absorption rgb<1,1,0>
                         //emission rgb <1,0,0>
         hollow
         translate 1*x
isosurface
         {                    //control
         material
                 texture
         interior
                 media
                         scattering {2}
                         density
                                 turbulence
                                 10
                 ior -1
                 caustics 1
         hollow
         translate -1*x
hollow
scale 2
Subject: Re: Trying to figure out media...
Date: 2 Nov 2004 01:20:39
Message: <41872737@news.povray.org>
I've tried changing ior to an inverse vaule, that resulted in a wierd,
inverted reflection in, i guess, the bubble of air.
im still looking for places to upload...any tips?
Date: 4 Dec 2004 18:57:28
Message: <41b24ee8@news.povray.org>
"Soace Munky" <alu### [at] gmailcom> wrote in message
news:41872737@news.povray.org...
I managed to render your script, minus the bubble.inc, plus seed() for the
random numbers. Obviously you're trying to get air bubbles to render
technically accurate or realistic. Fresnel reflection is most likely needed
in the water 'finish'. By having a different refraction (ior of air) for the
bubble (isosurface) it might be correct. As it stands now you only have
water refraction throughout. And you put media inside the air bubbles
instead of into the water, and it's the water you need to make murkier with
clear air in the bubbles.
You can post the files to povray.binaries.scene-files, after joining or
subscribing to that group like you did for this one. Just "attach" them to
the message (never attach files to non-"binaries" groups). There's also the
povray.text.scene-files group for text-only scene files put into the message
body.
Sorry for replying a month later, I haven't been here much these past few
months. Surprised to see no one else replied. Hope you had some success
yourself in the meantime.
Check the changes to your script below. BTW, you had used only rgbf for
rgbft color vectors.
Bob H.
/* water air bubbles */
                    noise_generator 2
                    max_trace_level 5
#declare Bubble=sphere {0,1}
   location <0,2.5,7>
   look_at   <1,0,0>
   rotate 35*y
                        scale 2
plane {
         y,-1
         material {texture {pigment {checker rgb 0 rgb 1}}}
#local R1=seed(123);
#local R2=seed(321);
#local R3=seed(231);
#declare water =
material
          finish
                 ambient 0 diffuse 0
                 phong 1.0
                 phong_size 100.0
                 reflection {0,0.9 fresnel on}
                 conserve_energy
       interior
                 ior 1.33
                 media
                         absorption rgb<0.9,0.6,0.3>/3
                         scattering {3,0.01}
difference {
      material {water}
isosurface
         {                    //Experiment
         max_trace 4
         max_gradient 1.6
         material
                 texture
                         pigment {color rgbft <0,0,0,0,1>}
         interior
                    ior 1.002
         hollow
         translate 1*x
isosurface
         {                    //control
         material
                 texture
         interior
                 media
                         scattering {2}
                         density
                                 turbulence
                                 10
                 ior 1
                 caustics 1
         hollow
         translate -1*x
hollow
scale 2
