POV-Ray : Newsgroups : povray.newusers : human modeling Server Time
11 Jul 2026 19:12:46 EDT (-0400)
  human modeling (Message 1 to 4 of 4)
Subject: human modeling
Date: 15 Sep 2004 22:05:36
Message: <4148f4f0$1@news.povray.org>
Hello,
Anny one knows where to find tutorials about human dodeling using
povray, google gaved no result.
Thanks
Subject: Re: human modeling
Date: 16 Sep 2004 05:56:06
Message: <41496336$1@news.povray.org>
"new'b" <none@com> wrote in message news:4148f4f0$1@news.povray.org...
> Hello,
> Thanks
As Manuel mentioned it's close to impossible ... but not totally impossible.
Option 1.
There is a human model called BlobMan which is done entirely using the
POVRay
Scene Description Language. The body parts look reasonably good and
are all parametrised so that you can define the position and rotation of
limbs
(right down to individual fingers). There is even a free Java utility on the
Internet
called Petibonum to help you pose the Blobman figure.
Option 2.
Otherwise, if you're not committed to having absolutely everything done
completely in POVRay you could look at POV-Person which uses a mesh
(generated
using a modeller) for the skin of the head and POVRay for almost everything
else (google search = <povray povperson>).
For the most part (and particularly for faces) you would probably want to
use
a POV-Ray mesh generated using a modeller.
I used this technique for the POV-Person skin surface and teeth and built
the
rest of the head (eyes, hair, makeup, textures etc.) using POVRay. This
enables
a range of different faces to be generated in POVRay from the same skin
model.
I've also done some work in combining this with the BlobMan body, creating a
sort of adapter to perform a head transplant. I know it sounds messy, but I
think it turned out OK.
The POVRay source files and sample renderings for all that I've done are
published on my POVPerson website along with links to the BlobMan and
Petibonum downloads.
There are descriptions of how I've done stuff along with examples of the
parameters used to generate different hair styles, eye colours etc.
It's not exactly a tutorial, but I think it will give you an indication of
what is possible. One word of warning, human modelling is probably not the
place to start if you are new to 3D modelling and POVRay.
Here's the URL - http://www.telinco.co.uk/c_bartlett/povperson/index.htm
Hope this helps,
Chris.
Date: 16 Sep 2004 17:00:00
Message: <web.4149fdc9641a08425c9b0b290@news.povray.org>
new'b <none@com> wrote:
> Hello,
> Thanks
POV-Ray is a great software to render a scene, but if you want to create a
human character, it is not so comfortable.
One solution, is to use an external modeller like Wings3D to construct your
character, then export it to Poseray, and finally export it to POV-Ray to
render the scene.
There is a VERY GOOD TUTORIAL by Michel Roger which explains from A to Z,
how to create a human body.
It guides you step by step, with each part of the body detailled. Modelling
Feet, legs, hands, head, eyes, ears, hairs, clothes, accessories, textures
Even if this tutorial was originaly made for 3D studio,  most of the
explanations  are valid for others modellers.
You can use it as guidelines.
A lot of beginners, started modelling their first body with it.
Here is the original link in French
http://mr2k.3dvf.net/tutorials/max/tutorials_joan.htm
And there, the English translation
http://www.3dtotal.com/ffa/tutorials/max/joanofarc/joanmenu.asp
Finally, a little image to show you the result.
http://mr2k.3dvf.net/galerie_3d/image_of_day_15_12_02.htm
Not so bad, don' t you think so ?
Date: 17 Sep 2004 11:51:21
Message: <414b07f9$1@news.povray.org>
Great Thanks to all.
I'm looking for Integrated Chips circuit or anny other electronic board
examples designed with Povray, anny one have some links ?
