POV-Ray : Newsgroups : povray.newusers : Problems declaring objects Server Time
11 Jul 2026 19:12:46 EDT (-0400)
  Problems declaring objects (Message 1 to 10 of 14)
Subject: Problems declaring objects
Date: 14 Sep 2004 16:30:41
Message: <414754f1@news.povray.org>
Why if I do this some objects move down?
The code is:
=============The camera==============
#include "shapes.inc"
#include "stones.inc"
#include "textures.inc"
#include "woods.inc"
#include "metals.inc"
#include "golds.inc"
#include "glass.inc"
#include "glass_old.inc"
global_settings { assumed_gamma 2 }
background { color White }
camera { location <-10, 8, -19> look_at <0, 5, 0> }
light_source { <0, 33, 0> color White spotlight point_at <0, 0, 0> radius 50
falloff 20 tightness 0  }
light_source { <0, 19, 0> color rgb <0.5, 0.5, 0.5> }
light_source { <40, 25, 0> color rgb <1, 1, 1>
spotlight
point_at <0, 5, 0>
radius 20
falloff 20  }
============The object================
//Inici del relotge.
//Per fer el marc.
#declare Reloj =
union {
  merge {
    box {<-5,0,-55>,<0,95,55>}
    cylinder{<-5,95,0>,<0,95,0>,55}
   texture { T_Wood15 } finish { specular .51 ambient 1 diffuse .96 }
  scale 0.1 no_shadow}
//Per fer l'esfera.
difference {
    cylinder{<-10,95,0>,<20,95,0>,40}
    cylinder{<-11,95,0>,< 6,95,0>,36}
    texture { T_Gold_1D } finish { specular 2 ambient 1 diffuse .07
reflection 0.1 phong 0.3 phong_size 30 }
    scale 0.1}
no_shadow
//Per fer els punts dels quarts.
#declare Puntos = union {
sphere { <0, 0, 0>, 0.1 pigment { color White } finish { ambient 1 }
translate <2.1, 9.7, -4> }
sphere { <0, 0, 0>, .1 pigment { color White } finish { ambient 1 }
translate <-5.4, 9.35, -4> }
translate <-2.2, 12.6, -4> }
translate <-2.2, 6, -4> }
no_shadow
//Agulles del relotge.
#declare Agulles = union {
box { <-1, 0, -3.5> <-0.8, .2, 3.5> pigment { color Black } finish { ambient
1 } translate <0, 9.5, -4> rotate <0, 0, 0> no_shadow }
box { <-1, 0, -1> <-0.8, .2, 0.5> pigment { color Black } finish { ambient
1 } translate <1.12, -0.5, -10> rotate <60, 30, 0> no_shadow }
//Cilindre que unix les agulles.
#declare Cilindre =
cylinder { <0, 0.9, -0.5> <0, 1, 1> 0.035 texture { T_Gold_1D } finish {
specular 2 ambient 1 diffuse .07 reflection 0.1 phong 0.3 phong_size 30 }
rotate y*25 rotate x*-2 translate <-3.18, 8.25, -6>
//Declarant les diverses parts.
#declare Todo_Reloj = union {
object { Reloj rotate y*115 translate <0, 0, 0> }
object { Puntos }
object { Agulles }
object { Cilindre }
//Declarant tot junt.
object { Todo_Reloj  no_shadow }
If I put this on the last line "object { Todo_Reloj scale 0.5 no_shadow }",
some objects change their position. Why??
Can anyone help me?
Thanks in advance,
Oleguer
Subject: Re: Problems declaring objects
Date: 14 Sep 2004 16:42:06
Message: <4147579e@news.povray.org>
  Because you are scaling 'Todo_Reloj' to half size.
  Every size and distance inside 'Todo_Reloj' will be halved.
Date: 15 Sep 2004 04:13:56
Message: <4147f9c4$1@news.povray.org>
So, what if have to do? scale all the objects a part to make it slower? Is
it a good idea?
Oleguer
news:4147579e@news.povray.org...
no_shadow }",
x]
Warp -
Date: 15 Sep 2004 05:25:12
Message: <41480a78$1@news.povray.org>
Instead of placing everything in a union{} at the end and naming it
Todo_Reloj, why not place the different objects by themselves and only scale
what needs to be scaled? Something similiar to this:
object { Reloj rotate y*115 translate <0, 0, 0> no_shadow scale 0.5}
object { Puntos  no_shadow}
object { Agulles  no_shadow}
object { Cilindre  no_shadow}
That way, only Reloj will be scaled and the rest left untouched.
Or, leave the #declare Todo_Reloj = union{---} around all the objects, but
just scale the one needing to be scaled.
Tim
"Tim Nikias v2.0"
Date: 15 Sep 2004 05:53:12
Message: <41481108$1@news.povray.org>
If I do this:
object { Reloj rotate y*115 translate <0, 0, 0> scale 0.5 }
object { Puntos }
object { Agulles }
object { Cilindre }
I thinks that is your idea, I can not see the other object on the correct
place. If I do this:
object { Reloj rotate y*115 scale 0.5 }
object { Puntos scale 0.5 }
object { Agulles scale 0.5 }
object { Cilindre scale 0.5 }
Some of the objects appear also moved.
I'm thinking....
Thanks,
Oleguer
mensaje news:41480a78$1@news.povray.org...
scale
> Regards,
> Tim
> "Tim Nikias v2.0"
> Homepage: <http://www.nolights.de>
Date: 15 Sep 2004 06:25:25
Message: <41481895@news.povray.org>
> If I do this:
> object { Puntos }
> object { Agulles }
> object { Cilindre }
Well, in your first example, you only scale Reloj, in your second example,
you scale all objects, which is just like you did before. Maybe you should
consult the Documentaion, Section 2.2.7 for some more information on
transformations.
The idea is simple: "translate" moves an object, "rotate" rotates an object
about the origin and the given axis', and "scale" scales/sizes an object in
relation to the origin (<0,0,0>). So, if an object is placed at <5,0,0> and
you scale it by .5, not only will the object's dimensions (e.g. its radius)
be sized down to half its original size, but the distance to the origin will
be sized down as well, thus placing the object at <2.5,0,0>.
Then, when you declare and union{} objects, they all get "glued" together,
so when you transform a union, all objects inside the union will get
transformed.
Now, if you want to scale an object's size, but not it's position, what do
you have to do? Let's say you've got a sphere at <5,0,0> and want to squish
it some along the x-axis, making it more disc-shaped. First, you'd have to
translate the sphere back to the origin, then you scale it, and then you
translate it back.
sphere{<5,0,0>,1
translate <-5,0,0>
scale <.25,1,1>
translate <5,0,0>
pigment{rgb 1}}
Now, for a sphere this is kinda pointless, as you could have placed it at
the origin from the beginning and thus save translating it back to the
origin:
sphere{<0,0,0>,1
scale <.25,1,1>
translate <5,0,0>
pigment{rgb 1}}
But that's the basic idea of how to transform objects. I don't know what
exactly you're after, but if you only want to scale certain parts of an
object, then only scale those, not the entire object.
Tim
"Tim Nikias v2.0"
Date: 15 Sep 2004 06:26:31
Message: <414818d7$1@news.povray.org>
"Oleguer Vilella" <ole### [at] infonegociocom> wrote in message
news:41481108$1@news.povray.org...
> I'm thinking....
When you scale an object, the only point of the object that won't move is the
point that rests at <0,0,0> (assuming that you're scaling all axis).
To understand what is happening, try the following scene using different values
for myScale. Note that we divide the radius of the spheres by the value of
myScale. This means that the scale size doesn't affect the radius of the
spheres, only their positions.
  location  <0.0, 0.0, -10.0>
  look_at   <0.0, 0.0,  0.0>
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
#declare myScale = 1;
sphere{
  0,0.25/myScale
  scale myScale
  pigment{rgb<1,0,0>}
sphere{
  1,0.25/myScale
  scale myScale
  pigment{rgb<0,1,0>}
Date: 15 Sep 2004 09:41:51
Message: <4148469f@news.povray.org>
Hello Tim,
I want to make all the object smaler. I understood your firts exemple and I
trayed it, but I don't understand your second exemple. You says:
sphere{<0,0,0>,1
scale <.25,1,1>
translate <5,0,0>
pigment{rgb 1}}
With the scale <.25, 1, 1>, how do you calculate the translate <5, 0, 0>?
If I put scale 5, how can I know the translate vector?
"for a sphere this is kinda pointless, as you could have placed it at the
origin from the beginning and thus save translating it back to the origin:"
Can you tray to explain me it again, please?
Thank you very much,
Oleguer
mensaje news:41481895@news.povray.org...
> > If I do this:
> > object { Puntos }
> > object { Agulles }
> > object { Cilindre }
correct
> transformations.
object
in
and
radius)
will
> transformed.
squish
> translate it back.
> sphere{<5,0,0>,1
> translate <-5,0,0>
> scale <.25,1,1>
> translate <5,0,0>
> pigment{rgb 1}}
> origin:
> sphere{<0,0,0>,1
> scale <.25,1,1>
> translate <5,0,0>
> pigment{rgb 1}}
> Regards,
> Tim
> "Tim Nikias v2.0"
Date: 15 Sep 2004 09:58:24
Message: <41484a80@news.povray.org>
That's actually pretty simple: first, Povray scales the object, afterwards
it translates it to <5,0,0>. Since the sphere is already located at the
origin, the position of the sphere won't change when scaling it. Thus, it
will be squashed a little, but still be positioned at <0,0,0>. So, if I want
to place the sphere at <5,0,0>, I just have to translate it there.
origin:"
The same as above: positions of objects only change when they are not
centered at the origin, since scaling would not only scale the object, but
also its distance to the origin.
The sphere requires a center vector and a radius. If the center vector is
<0,0,0>, the sphere is sitting right on the origin, and scaling it will only
affect the size.
But, if you place the center of the sphere somewhere else, scaling would
also affect the position/center of the sphere. Hence, we need to move it to
the origin first, scale it, and move it back, if we want to retain its
position, but not its size.
Tim
"Tim Nikias v2.0"
Date: 15 Sep 2004 10:15:01
Message: <41484e65@news.povray.org>
Well, Tim, just a minute... I think that I'm doing it right now.
mensaje news:41484a80@news.povray.org...
0>?
want
the
> origin:"
only
> affect the size.
to
> Regards,
> Tim
> "Tim Nikias v2.0"
