POV-Ray : Newsgroups : povray.newusers : light_source Server Time
30 Sep 2024 10:22:09 EDT (-0400)
  light_source (Message 1 to 3 of 3)
Subject: light_source
Date: 8 Sep 2004 13:35:42
Message: <413f42ee@news.povray.org>
Hello,
I'm traying to make this object more luminous. I'm using this lights because
I will put this object to an other scene and I need this lights.
I was searching on the help file and I found the "Spotlights", I trayed with
it, but it didn't work well.
The camera and the lights:
global_settings { assumed_gamma 2 }
background { color White }
camera { location <-10, 8, -19> look_at <0, 5, 0> }
light_source { <0, 33, 0> color White spotlight point_at <0, 0, 0> radius 50
falloff 20 tightness 0  }// My test.
light_source { <0, 19, 0> color rgb <0.5, 0.5, 0.5> }
light_source { <40, 25, 0> color rgb <1, 1, 1>
spotlight
point_at <0, 5, 0>
radius 20
falloff 20  }
The object:
#declare Reloj =
union {
  merge {
    box {<-5,0,-55>,<0,95,55>}
    cylinder{<-5,95,0>,<0,95,0>,55}
   pigment { color Green }
  scale 0.1}
difference {
    cylinder{<-10,95,0>,<20,95,0>,40}
    cylinder{<-11,95,0>,< 6,95,0>,36}
    pigment{color Black}
    finish {reflection 0.1 phong 0.3 phong_size 30}
  scale 0.1}
object { Reloj rotate y*115 translate <0, 0, 0> }
Thanks in advance,
Oleguer
http://www.infonegocio.com/oleguervm
Subject: Re: light_source
Date: 8 Sep 2004 17:50:00
Message: <web.413f7d74d9eae58548cbffb00@news.povray.org>
Hi Oleguer,
had a quick look at the file.
heres the work around.
you forgot to apply the finish to the green only the ring :)
try this script to see the difference.[START]
background { color rgb 1 }
spotlight
point_at <0, 5, 0>
radius 20
falloff 20  }
#declare Reloj =
union {
  merge {
   pigment { color rgb<0,1,0> } finish{specular .51 ambient 1 diffuse
..96}//this is the main line you missed the finish only affected the ring in
the next part.
  scale 0.1}
difference {
    finish {specular 2 ambient 1 diffuse .07 reflection 0.1 phong 0.3
phong_size 30}
  scale 0.1}
// perspective (default) camera
  location  <0.0, 10.0, 55.0>
  look_at   <0.0, 0.0,  0.0>
[END]
"Oleguer Vilella" <ole### [at] infonegociocom> wrote:
> Hello,
Date: 9 Sep 2004 03:35:02
Message: <414007a6$1@news.povray.org>
Hi Sprocket,
Yes, I forgot to add the finish. I knew it, I'm sorry. I have thinking about
a cylindrical or conical light.
Thank you very much.
Oleguer.
news:web.413f7d74d9eae58548cbffb00@news.povray.org...
> Hi Oleguer,
50
> spotlight
> point_at <0, 5, 0>
> radius 20
> falloff 20  }
> #declare Reloj =
> union {
>   merge {
in
> the next part.
>   scale 0.1}
> difference {
> phong_size 30}
>   scale 0.1}
> camera {
> [END]
> > Hello,
because
with
