POV-Ray : Newsgroups : povray.newusers : Resolutions Server Time
17 Jan 2026 16:33:58 EST (-0500)
  Resolutions (Message 1 to 9 of 9)
Subject: Resolutions
Date: 12 Aug 2004 16:36:10
Message: <411bd4ba@news.povray.org>
Hello,
I did an image and I have to print in a 1200x900 cm poster. What resolution
should I use?
Thanks in advance,
Oleguer
Subject: Re: Resolutions
Date: 12 Aug 2004 16:54:47
Message: <411bd917$1@news.povray.org>
"Oleguer Vilella" <ole### [at] infonegociocom> wrote in message
news:411bd4ba@news.povray.org...
> Hello,
resolution
> should I use?
> Thanks in advance,
> Oleguer
forgive my non-metric upbringing, but isn't 1200x900 centimeters equal to
12x9 meters? that's freaking huge.
Date: 12 Aug 2004 17:54:58
Message: <411be732$1@news.povray.org>
Yes, 12 meters and 90 cm. The high 12 meters and the width is 90 cm.
Oleguer
news:411bd917$1@news.povray.org...
> > Hello,
> resolution
> > should I use?
> > Thanks in advance,
> > Oleguer
Date: 12 Aug 2004 17:58:02
Message: <411be7ea$1@news.povray.org>
Ohhhhh, no, I'm sorry. That's 1'2 meters and 90 cm.
Really sorry.
news:411be732$1@news.povray.org...
> Regards,
> Oleguer
> > > Hello,
> > resolution
> > > should I use?
> > > Thanks in advance,
> > > Oleguer
to
Date: 12 Aug 2004 18:02:47
Message: <411be907@news.povray.org>
You are ok.
1 mt = 100 cmt then 1200x900 cmt = 12x9 mt.
Anyway the resolution is more related to the printer resolution, if your
printer has by example a resolution of 300 dpi (dot per inch) and you image
is 1200x900 cm = to 472.4 x 354.3 inches then the image in pixels is =
141720 x 106290 or (1200/2,54*300)x(900/2,54*300). And yes, is freaking huge
:D
Salu2.
> > Hello,
> resolution
> > should I use?
> > Thanks in advance,
> > Oleguer
Date: 12 Aug 2004 18:58:37
Message: <411bf61d@news.povray.org>
> :D
  POV-Ray can't render an image that big simply because the image file
would be too large.
  Well, the 32-bit version of POV-Ray can't. You'll have to use the 64-bit
version is a 64-bit system.
  But anyway, there was a mistake by one order of magnitude in the original
request, so the image only needs to be a hundred times smaller.
Date: 13 Aug 2004 02:20:42
Message: <411c5dba$1@news.povray.org>
No, I did a mistake. The size is 1'2 meters and 90 cm.
Im sorry.
What do you do think about it?
news:411be907@news.povray.org...
> You are ok.
huge
> :D
> Salu2.
> > > Hello,
> > resolution
> > > should I use?
> > > Thanks in advance,
> > > Oleguer
to
Date: 13 Aug 2004 19:55:01
Message: <411d54d5@news.povray.org>
Oleguer Vilella nous apporta ses lumieres ainsi en ce 13/08/2004 02:14... :
>image
>huge
>>:D
>>Salu2.
Often, for large images (over a feet whide or high, even more so for
around a meter), you are assumed to look from some distance. Taking this
into consideration, it can be possible to use a MUCH lower resolution
and use rescaling when printing. Just look at advertisement in the metro
(if your city have one), or street level billboards. If you look close,
it's *VERY* grainy, but get's OK if you get back a few steps, even 1
meter is generaly enough. It's very easy to print 100*100 dots for every
1*1 pixel... and using error diffusion dithering, you may never notice
that each pixel is repeated 100*100 times.
Remember that you can print a 72 DPI image at 1600 DPI, without
shrinking it, it just have a lot of very fine dithering.
Date: 14 Aug 2004 00:21:26
Message: <411d9346@news.povray.org>
OK, the hard way is trace the image in printer resolution.
first translate from metric to inches: 1,2 mt = 47,24 inches // 0,90 mt =
35,43 inches
next step is use the printer resolution, let say for a 300 dpi printer
resolution: 47,24 inches = 14172 pixels // 35,43 inches = 10629 pixels.
(multiply the size in inches by the resolution in dpi)
then your ouput in pov need to be 14172 x 10629.
The easy way is render the image in a more reliable size without change the
relation w/h = 1.3333~ and scaling later at print. by example 2362 x 1772
pixels and scaling in a factor of 6 or 600%.
Sorry my ugly english, i do my best
Salu2.
news:411c5dba$1@news.povray.org...
> Im sorry.
> > You are ok.
> image
> huge
> > :D
> > Salu2.
> > > > Hello,
> > > resolution
> > > > should I use?
> > > > Thanks in advance,
> > > > Oleguer
> to
