POV-Ray : Newsgroups : povray.newusers : CSG union Server Time
17 Jun 2026 14:20:14 EDT (-0400)
  CSG union (Message 1 to 6 of 6)
Subject: CSG union
Date: 29 Jun 2004 13:14:50
Message: <40e1a38a$1@news.povray.org>
I'm having a problem with POV-ray that I don't understand. Scenes that I build
frequently produce this warnning:
Parse Warning: CSG union unnecessarily bounded
I'm not sure what causes this. I use one union that looks like this:
#declare A = union{
    object{ X }
    object{ Y }
    object{ Z }
Ofcourse each object has the necessary scale, transform etc. modifiers, I left
them out for simplicity reasons.
Now, I'm *assuming* that the above structure is not correct and produces the
parse warning, but I have no idea what I'm doing wrong or how I can improve
this.
Any suggestions are welcome.
Maurice
Subject: Re: CSG union
Date: 29 Jun 2004 13:34:38
Message: <40e1a82e$1@news.povray.org>
"SomeOne" <ask### [at] yahoocouknospam> wrote in message
news:40e1a38a$1@news.povray.org...
> Hi,
build
> #declare A = union{
>     object{ X }
>     object{ Y }
>     object{ Z }
this is correct syntax. how are you defining objects X, Y, and Z?
Date: 29 Jun 2004 14:26:45
Message: <40e1b465@news.povray.org>
  You are using bounded_by statements which (POV-Ray thinks) are
unnecessary.
  It's just a warning. You can ignore it.
Date: 29 Jun 2004 15:36:13
Message: <40e1c4ad$1@news.povray.org>
You can ignore it indeed, but it is better to understand why the warning is
given.
JWV
news:40e1b465@news.povray.org...
> unnecessary.
Date: 29 Jun 2004 15:49:38
Message: <40e1c7d2@news.povray.org>
"Ross" <rli### [at] everestkcnet> schreef in bericht
news:40e1a82e$1@news.povray.org...
| > Hi,
| build
| > #declare A = union{
| >     object{ X }
| >     object{ Y }
| >     object{ Z }
E.g. X is declared as:
#declare X =
#include "file1.inc"
#include "file2.inc"
object
{ X2 }
"file1.inc" contains a set of declares that are used in the macro X2.
"file2.inc" defines the macro X2.
Date: 29 Jun 2004 16:13:05
Message: <40e1cd51@news.povray.org>
> given.
  Sure. Usually, however, if he is writing bounded_by blocks he is just
wasting his writing work for nothing, but not doing anything which would
affect negatively render times.
  Usually when a user-defined bounding box is smaller than the one
POV-Ray calculates (or if the object doesn't have any bounding box
by default), POV-Ray will accept it.
  There may be a few cases where POV-Ray gets it wrong and the user-defined
bounding box may be more optimal, and if you think this is so, you can
turn off the check with a command-line option.
