POV-Ray : Newsgroups : povray.newusers : creating irregular surfaces Server Time
20 Aug 2025 23:45:35 EDT (-0400)
  creating irregular surfaces (Message 1 to 2 of 2)
Subject: creating irregular surfaces
Date: 28 Jun 2004 23:09:52
Message: <40e0dd80$1@news.povray.org>
Hi, im trying work out to make good irregular surfaces on objects (that
will show on both the object and the objects shadow). From the searching
that i have done so far is that it seems that an isosurface might do
what i am after. Basically i want to create a rough surface like you
would find on the road.
I have read a little on isosurfaces but im am unsure how to apply it to
an object.
Subject: Re: creating irregular surfaces
Date: 29 Jun 2004 00:58:01
Message: <40e0f6d9$1@news.povray.org>
"Martin" <1@1.1> wrote in message news:40e0dd80$1@news.povray.org...
> an object.
Well, the object needs to be the isosurface itself. Maybe a CSG
(intersection or difference) of the two, anyway.
Okay, I could be giving an incorrect or partial answer here but I think I'm
right enough to say that there are no surface deformations you can apply to
a predeclared object; unless you are working with something like mesh or
mesh2, or an isosurface to begin with, in which you could rearrange the
original surface.
Lets take your road idea:
#include "functions.inc"
isosurface {
  function {
  y // origin surface
  + // add the following function to it
  f_noise3d(x*5,y,z*5) // scale inversely by multiplying x,y and/or z
  0.25 // effects amount of noise
  contained_by {
    box { <-10,-1,-10>,<10,0,1000> } // maximum, or desired, dimensions
  max_gradient 2
  pigment { color rgb 0.5 }
  finish { specular 0.1 roughness 0.1 }
camera { location <0,10,-1> look_at <0,5,10> }
light_source { <-100,100,-100>, color rgb <1,1,1> }
/* for round objects (rocks) you'd want to use x*x+y*y+z*z instead of y for
the origin surface, as well as a sphere {0,1} instead of a box */
Bob H.
http://www.3digitaleyes.com
