POV-Ray : Newsgroups : povray.newusers : tapering an object Server Time
17 Jan 2026 20:02:47 EST (-0500)
  tapering an object (Message 1 to 4 of 4)
Subject: tapering an object
Date: 16 May 2004 14:51:21
Message: <40a7b829$1@news.povray.org>
In this case an isosurface - is there a way of transforming an isosurface so
thet the top is made thinner than the bottom?
Mick
Subject: Re: tapering an object
Date: 16 May 2004 16:00:12
Message: <40a7c84c$1@news.povray.org>
Mick Hazelgrove nous apporta ses lumieres ainsi en ce 2004/05/16 14:52... :
>Mick
Yes by using an inverted gradient y to modulate the horizontal size.
With a maximum value at the bottom reatching zero at the top, you
multiply the x and z sizes by the gradient value. You can also use some
function that depend on the vertical position if you want a non-linear
tapering.
Date: 17 May 2004 13:18:01
Message: <oBNWOBAgUHqAFwfa@econym.demon.co.uk>
Here's a non-linear taper:
#declare F to be your original function(x,y,z) then use
isosurface {
     function{F(x*(1.5+y/2),y,z*(1.5+y/2))}
This tapers from the initial width at y=-1 to half the width at y=1
Mike Williams
Gentleman of Leisure
Date: 20 May 2004 17:02:08
Message: <40ad1cd0@news.povray.org>
Thanks
I'd almost forgotten I'd posted this as the problem has changed direction,
however now I've seen your replys I'll integrate this - somehow!
