POV-Ray : Newsgroups : povray.newusers : perspective views of arc projects Server Time
21 Nov 2025 00:45:55 EST (-0500)
  perspective views of arc projects (Message 1 to 9 of 9)
Subject: perspective views of arc projects
Date: 21 Apr 2004 06:42:09
Message: <40865001@news.povray.org>
I'm interested start using POV-RAY to create photo-realistic perspective
views of architecture projects. I would receive the autocad files from the
clients and would give them the desired views. I've been studying the
Tutorial (wich is Great!) and I have some questions:
- Is Pov-Ray capable to REALLY predict (I'm not demanding 100% realism) the
illumination of a building (or one of its pieces) if I mix the raytracing
and radiosity methods? The textures and the materials work fine in this
approach?
- Suggestions of other softwres to support POV-RAY modeling of the scene?
- Any Methodology to the process? (maybe someone in the list works with
similar stuff)
Other comments are also very welcome.
Thanks,
Rodrigo
Subject: Re: perspective views of arc projects
Date: 22 Apr 2004 05:40:33
Message: <40879311$1@news.povray.org>
"Rodrigo Almeida" <rod### [at] hotmailcom> wrote in message
news:40865001@news.povray.org...
> approach?
In the absence of any other reply, I'd offer a tentative yes to this. The
complication IMHO is that there is no obvious way to know what the realistic
finish would be to simulate the real-life radiosity of any particular material -
e.g. if you want to simulate concrete, what value of diffuse and amibient should
you use?
I believe you've already been pointed at some autocad->pov tools - you might
take a look at moray if you want to model other aspects of the scene, but the
pov sdl is really the way to go - it will give you far better access to macros
and utilities written by others, and far better control in the long run.
> similar stuff)
iirc there is a pov-user who does some very impressive architectural renderings
using pov - anyone have a name? a link?
Date: 22 Apr 2004 06:52:40
Message: <4087a3f8@news.povray.org>
  No. Raytracing is only an approximation. A pretty good one, but only
an approximation. The stochastic illumination model used with 'radiosity'
is even a rougher approximation of illumination between surfaces. You can
get pretty images, but you can't expect them to be 100% accurate, even if
you have a 100% accurate model of your scene (which in itself is impossible
as well). You can approximate reality quite well, but 100% accuracy is just
not possible.
Date: 22 Apr 2004 07:26:17
Message: <4087abd9$1@news.povray.org>
the
raytracing
> an approximation.
SNIP
> not possible.
Well, didn't he say that he's not demanding 100% realism? ;-)
"Tim Nikias v2.0"
Date: 22 Apr 2004 08:12:18
Message: <4087b6a2@news.povray.org>
  I somehow misread his statement inside the parentheses so that I
understood it to mean the complete opposite.
  Perhaps I'm getting too old for this.
Date: 22 Apr 2004 08:32:00
Message: <4087bb40$1@news.povray.org>
It depends on what you mean with "this". Reading? Then just get some glasses
and you're good to go. ;-)
"Tim Nikias v2.0"
Date: 22 Apr 2004 12:14:55
Message: <4087ef7f@news.povray.org>
"pov sdl" is Pov sdk?
Thanks, I'll take a look at Moray, and for the lighting stuff I think with
the time ans the mistakes I will try to get more intuitive for the effects
and properties of each component...
news:40879311$1@news.povray.org...
the
raytracing
> > approach?
realistic
material -
should
> you use?
scene?
might
the
macros
> > similar stuff)
renderings
Date: 22 Apr 2004 12:19:15
Message: <4087f083$1@news.povray.org>
news:4087ef7f@news.povray.org...
"pov sdl" refers to the POV-Ray Scene Description Language.
-ross
Date: 22 Apr 2004 12:56:49
Message: <cjameshuff-08A359.12553922042004@news.povray.org>
In article <4087ef7f@news.povray.org>,
POV-Ray doesn't have a SDK (software development kit). Around here,
"SDL" usually refers to the Scene Description Language.
http://tag.povray.org/
