POV-Ray : Newsgroups : povray.newusers : wrapping textures around an object Server Time
18 May 2026 10:22:16 EDT (-0400)
  wrapping textures around an object (Message 1 to 5 of 5)
Subject: wrapping textures around an object
Date: 12 Apr 2004 01:54:29
Message: <407a2f15@news.povray.org>
whenever i use image_map to map a texture onto a box of any size, only the
front and back is textured leaving the top and sides all wierd and stretched
looking ... (the texture bricks is just declared becasue i use it often in
my scene)
#declare bricks = texture {
  image_map {
   "stone.bmp"
      map_type 0
      interpolate 2
  scale 10
box {
 <-20, -10, 5>, <20, 2.7, 10>
 texture { bricks }
.. i just want the brick texture to show up everywhere on the box.
help appreciated
Subject: Re: wrapping textures around an object
Date: 12 Apr 2004 03:58:30
Message: <407a4c26$1@news.povray.org>
> my scene)
>  pigment {
>   image_map {
>    "stone.bmp"
>       map_type 0
>       interpolate 2
>   scale 10
> box {
>  texture { bricks }
> help appreciated
POV textures are 3D textures, which means they have a value in every
point of space.
Quote from POV documentation:
" By default, the image is mapped onto the x-y-plane. The image is
projected onto the object as though there were a slide projector
somewhere in the -z-direction. The image exactly fills the square area
from (x,y) coordinates (0,0) to (1,1) regardless of the image's original
size in pixels."
So when you create a texture with an image map, it can be seen only on
planes in the (x,y) direction, on other planes the streched parts you
see are the borders of the image.
If you want to use your texture on the box, you will have to create
separately the 6 faces and assigning the texture to them with proper
rotations.
I hope that helps,
JC
http://exether.free.fr/irtc (more IRTC stats !)
Date: 12 Apr 2004 05:50:50
Message: <407a667a@news.povray.org>
> rotations.
If the object supports it (which is the case with a box), you can also
use uv_mapping. See the documentation, section 6.7.7 (which can be found
online at http://www.povray.org/documentation/view/191/).
HTH,
Florian
Date: 12 Apr 2004 16:40:16
Message: <407afeb0@news.povray.org>
"Florian Brucker" <tor### [at] torfboldcom> wrote in message
news:407a667a@news.povray.org...
> > rotations.
> HTH,
> Florian
well this works, but now the sizes of the texture differ from side to side
(top of the box shows the texture with the right sizing, but the side of the
box has the texture all stretched) by using differnt scaling i can sorta
make them close to the same, but theres gotta be a better way to do this?
Date: 12 Apr 2004 18:00:54
Message: <407b1196$1@news.povray.org>
"JC (Exether)" <no### [at] spamfr> wrote in message
news:407a4c26$1@news.povray.org...
the
stretched
in
> > my scene)
> >  pigment {
> >   image_map {
> >    "stone.bmp"
> >       map_type 0
> >       interpolate 2
> >   scale 10
> > box {
> >  texture { bricks }
> > help appreciated
> point of space.
> size in pixels."
> rotations.
> I hope that helps,
> JC
You could cut that to three by declaring your box and having 3 almost
identical, but differently scaled copies with the texture rotated on each
copy.
I moved your box a little so it stradles the origin (so that when it scales
it gets a tiny bit bigger in both the positive and negative direction).
#declare wall = box {<-20, -10, -2.5>, <20, 2.7, 2.5>}
object {wall scale <1,1,1.0001> texture { bricks}}
object {wall scale <1.0001,1,1> texture { bricks rotate y*90}}
object {wall scale <1,1.0001,1> texture { bricks rotate x*90}}
Any good?
