POV-Ray : Newsgroups : povray.newusers : How do you get just a piece of the image Server Time
30 Sep 2024 18:07:57 EDT (-0400)
  How do you get just a piece of the image (Message 1 to 4 of 4)
Subject: How do you get just a piece of the image
Date: 5 Mar 2004 01:44:55
Message: <404821e7@news.povray.org>
I have raytracing that is 200x200 and I want to extract just the upper right
20x20 pixel corner. I thought
+W200 +H200 +SC180 +ER20
would do the trick but the result is still a 200x200 file with all but my
desired square blackened out. But I don't want a 200x200 file. I want a
20x20 file that has that upper right corner and nothing else. Is there some
way to do this without resorting to manual cropping with an external
graphics program?
Thanx,
Apchar
No one is safe while the legislature is in session. -- Mark Twain
Subject: I forgot to say I am using POVRAY
Date: 5 Mar 2004 01:48:56
Message: <404822d8@news.povray.org>
Sorry. I forgot to mention that I'm using povray for linux.
Subject: Re: How do you get just a piece of the image
Date: 5 Mar 2004 11:29:08
Message: <4048aad4@news.povray.org>
Short Answer:
No
Long Anser:
You will always get an image-file which fills the whole space of the
original size. There have been discussions about that, but the search of
the news-interface is down ATM, so I can't give you any links.
HTH,
Florian
Date: 6 Mar 2004 22:11:52
Message: <404a92f8@news.povray.org>
right
some
> graphics program?
Transforming the camera can work, example
// +h200 +w200
// -uv +h20 +w20
#declare Shear= transform {
   matrix <  .21,  0,  0,
             0,  .21,  0,
             .9,  .9,  1,
             0,  0,  0 >
        perspective
        location <0,0,0>
        right <1,0,0>
        look_at <0,0,10>
        // transform Shear
box {<-10,-10,10>,<10,10,11>
     pigment {checker rgb<1,1,1>,rgb<0,0,0>}
sky_sphere {pigment {rgb <0.859,0.910,0.831>}}
light_source {<100,120,-130> rgb<10,10,10>}
The transformation you need depends on the camera location and the direction
it's looking. I've chosen the easiest, with the location at <0,0,0>, looking
along the positive z direction. The .21 scales the view (.2 perfect fit) and
the .9 skews the image plane to the upper right corner. When using a
transformation like this, you need to turn off the vista buffer (-uv). The
only way to get a 20 x 20 final render is to use +h20 +w20.
I hope this is correct :-)
