POV-Ray : Newsgroups : povray.newusers : vector data structure Server Time
21 Mar 2026 09:22:33 EDT (-0400)
  vector data structure (Message 1 to 7 of 7)
Subject: vector data structure
Date: 20 Feb 2004 15:42:41
Message: <40367141@news.povray.org>
    I assume this can be found somewhere in some documents. If you know it
from the top of your head, please let me know.
    I am trying to change one components of a vector:
#declare pt = <0,0,0>;
#declare pt = VRand_On_Sphere(MySeed);
#declare pt.z = pt.z / 2.0;
The third line does not process, saying that  a '=' is expected but a '.' is
found. The docs indicate that it should work. Am I declaring my variable pt
wrong?
Thanks for your help.
bongo
Subject: Re: vector data structure
Date: 20 Feb 2004 16:27:13
Message: <40367bb1@news.povray.org>
> wrong?
  Actually I'm not sure now whether assigning to a vector component should
work or not according to the documentation...
  Anyways, you can get that working like this (a bit longer, but at
least it should work):
#declare pt = <pt.x, pt.y, pt.z/2>;
  In fact, this should work as well:
#declare pt = pt*<1, 1, 0.5>;
Date: 20 Feb 2004 17:01:31
Message: <403683bb@news.povray.org>
As far as I've understood the docs, doing a .x or such, like Vector.x, would
not return a "handle" to the X-Component of the Vector, but actually return
the value stored there. So Vector.x actually IS a value, not a reference. If
the Vector would be <1,1,1>, then
#declare Vector.x = Vector.x/2;
would be like
#declare 1 = 1/2;
which obviously wouldn't work (on a logical basis, not sure how the parser
handles that).
Tim
"Tim Nikias v2.0"
Email: tim.nikias (@) nolights.de
Date: 21 Feb 2004 06:11:15
Message: <kurtzlepirate-936ACA.12111421022004@news.povray.org>
In article <40367141@news.povray.org>, "bongotastic" <cbl### [at] csdalca> wrote:
> Hi,
> wrong?
> bongo
  #set pt = <pt.x, pt.y, pt.z*0.50>;
Date: 21 Feb 2004 08:40:58
Message: <40375fea@news.povray.org>
Kurts <kur### [at] yahoofr> wrote:
>   #set
  Yeah, sure.
Date: 21 Feb 2004 12:24:35
Message: <cjameshuff-07C09D.12251521022004@news.povray.org>
In article <kurtzlepirate-936ACA.12111421022004@news.povray.org>,
Or something which matches what he's doing more closely:
#declare pt = pt/<1, 1, 2>;
And be aware that #set is a MegaPOV-only feature.
http://tag.povray.org/
Date: 21 Feb 2004 13:29:07
Message: <4037a373$1@news.povray.org>
Thanks all for the pointers.  I did not get from the docs that vector.x was
a returned value rather than a reference handle.
#set is indeed not in povray's documentation.
Cheers,
