POV-Ray : Newsgroups : povray.newusers : shape generation (functions and more) Server Time
12 Jun 2026 23:31:56 EDT (-0400)
  shape generation (functions and more) (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: shape generation (functions and more)
Date: 16 Feb 2004 20:21:16
Message: <40316c8c$1@news.povray.org>
"lars petter" <lar### [at] higno> wrote in message
news:4030e7fc$1@news.povray.org...
> I'll try again.. (sorry for any inclarities, i dont exactly know what i'm
> asking for :) )
I've seen your original message post at the programming group.
> The view in the tool will be in the x,y plane, viewed from top.. in the
> "drawing board" they will place differented shapes suchs as bezier curves,
> parabolas, circles (closed, open), ellipes (closed, open), and so on.
these
> shapes will have user-specific properties regarding to absorption,
> diffusion, width, and color. After placing a light source, we want to
render
> the scene in povray. The main point is to illustrate the caustics
generated
> by the system of mirrors in the scene..
So you'll be using photons, no doubt.
> Anyway, we've looked at the documentation, and tested a little "coding",
and
> concluded with that we probably should use the prism object to generate
the
> pov-ray figures, at least the bezier shapes.
You could be right about that. Not real sure myself.
> We've also looked at the various internal/math/whatever-functions in the
> .inc files, but we really cant understand how we actually use these to get
> shapes into the scene.. i'm looking at:
> Quartic_Paraboloid
> Quartic parabola - a 4th degree polynomial (has two bumps at the bottom)
> that has been swept around the z axis. The equation is:
> 0.1 x^4 - x^2 - y^2 - z^2 + 0.9 = 0
> how do i use this?
> all in all, we do have the mathematical parametres from the 2d-plane, and
> what we're looking for is some easy way to apply these to generate the 3d
> figures..
Isosurfaces seem the most plausible thing to me, since you'll be working
with equations anyhow. I've taken the example for f_quartic_paraboloid()
from the scenes\incdemo\i_internal.inc to make:
  location  <0.0, 0.0, -5.0>
  look_at   <0.0, 0.0, 0.0>
sky_sphere {
    gradient y
    color_map {
      [0 rgb <0.9,0.9,0.9>]
      [1 rgb <0.3,0.3,0.3>]
light_source {
 -100*z,
 color rgb <1, 1, 1>
  rotate <15, 15, 0>
#include "functions.inc"
#declare IsoQP=
isosurface {
 function  {
  // f_quartic_paraboloid(x,y,z, -0.01)
  0-(0.5*x*x*x*x-x*x-y*y-z*z+0.5)
 // contained_by {box { <-1.45, -0.1, -1.45>, <1.45, 2.5, 1.45> }}
 max_gradient 2.5
 all_intersections
difference {
object { // outside
    IsoQP
    material {
      pigment {color rgb 0.75}
      finish {reflection {0.3,0.9}}
object { // inside
    IsoQP
    scale <0.95,0.95,0.95>
    translate y/6
    material {
      pigment {color rgb 0.25}
      finish {reflection {0.1,0.3}}
// rotate -90*x // turn to look into parabloid
Maybe you can figure something out from this and by reading up on isosurface
functions. I'm not very good at the math, and you should be warned that the
carat (^) sign is not used in POV-Ray. If you'll be needing semitransparent
materials, the above texturing won't suffice to blend from one side to the
other.
Bob H.
Date: 17 Feb 2004 07:57:30
Message: <40320fba$1@news.povray.org>
thanks, we've gotten some basic knowledge on the isosurfaces now.
    the problem is, they're only surfaces, not solid figures with a certain
width, so we're wondering if there is a way to, e.g., extrude a parabola 2
units, making it solid? that would've been smooth, he he. or do you see some
other way?
(sorry about the double posting with binary attached, first, i was about to
post in a .binaries group, but i found out that i
didnt need the image, so i posted here instead. however, i forgot to remove
the image. sheesh. =) )
- lars petter
"Hughes, B." <omn### [at] charternet> wrote in message
news:40316c8c$1@news.povray.org...
i'm
> > asking for :) )
curves,
> these
> render
> generated
> and
> the
get
> > Quartic_Paraboloid
> > how do i use this?
and
3d
> > figures..
> camera {
> sky_sphere {
>   pigment {
>     gradient y
>     color_map {
> light_source {
>  -100*z,
>  color rgb <1, 1, 1>
>   rotate <15, 15, 0>
> #declare IsoQP=
> isosurface {
>  function  {
>  max_gradient 2.5
>  all_intersections
> difference {
> object { // outside
>     IsoQP
>     material {
>      texture {
> object { // inside
>     IsoQP
>     translate y/6
>     material {
>      texture {
isosurface
the
semitransparent
> other.
> Bob H.
Date: 17 Feb 2004 09:12:15
Message: <4032213f$1@news.povray.org>
news:40320fba$1@news.povray.org...
> other way?
? do you mean you only want surfaces, or that isosurfaces are only surfaces? If
the latter, you need to revise your understanding of iso-surfaces.... (and
possibly take a look at some of the iso keywords, such as all_intersections ?).
s*** happens.... ;)
Date: 17 Feb 2004 10:08:21
Message: <40322e65$1@news.povray.org>
> other way?
Here's an iso-surface w/ photons etc. for a shape based on sin(x).
I've given it some thickness by differencing the function from an off-set copy
of itself (otherwise the shape would be infinitely thick). I've slightly
coloured the glass to make the shape show up a little more clearly than would
otherwise be the case. Adjust spacing to meet your requirements/patience...
#version 3.5;
global_settings {
  assumed_gamma 1.0
  max_trace_level 10
  photons {
    spacing 0.005 //smaller = better but slower
  location  <0,5,-5>
  look_at   0
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
#declare fn_X = function(x,y,z){y-sin(x)}
isosurface {
  function { max(fn_X(x, y, z), - fn_X(x,y+0.5,z)) }
  contained_by { box {<-2,-10,-1>,<2,10,1> } }
  accuracy 0.001
  max_gradient 4
  all_intersections
  pigment{rgbf<0.9,0.9,1.0,1.0>}
  finish{reflection{fresnel}}
  interior{ior 1.5}
  photons{
    target 1
    refraction on
    reflection on
    collect off
plane{y,-2 pigment{White}}
Date: 17 Feb 2004 12:36:55
Message: <40325137@news.povray.org>
> how do i use this?
No idea - but this is weird looking if nothing else.... (I've put the abs bit in
since you specified =0 rather than <=0 )
#declare fn_Xb = function(x,y,z){0.1*pow(x,4) - x*x - y*y - z*z + 0.9}
isosurface {
  function { abs(fn_Xb(x, y, z)) - 0.1}
  contained_by { box {-10,10 } }
  accuracy 0.001
  max_gradient 250  // Eeeek!!!
  all_intersections
  pigment{Red}
Date: 17 Feb 2004 13:51:35
Message: <X7A9iJAx5lMAFwrB@econym.demon.co.uk>
>other way?
I'm not sure if this is what you want, but there's a trick for creating
"thick" isosurfaces in my isosurface tutorial
<http://www.econym.demon.co.uk/isotut/substitute.htm#thick>
Mike Williams
Gentleman of Leisure
Date: 17 Feb 2004 16:15:38
Message: <4032847a$1@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:40325137@news.povray.org...
> > how do i use this?
bit in
> isosurface {
>   accuracy 0.001
>   all_intersections
>   pigment{Red}
Hey, what's with that huge container Tom?? I managed to get a much faster
render by lowering it to a -1,1 size! Heh-heh. Curious shape, I don't know
what it is either mainly because I don't know how much of it is visible.
I figured a way to get just a surface sheet. Maybe compatible with Mike
Williams' iso-thickener? Probably not, I haven't checked. I should have
realized this before, but these function things will always be new to me. I
took Tom's iso and simply removed the y parameter from the function itself.
Here is a whole scene showing it in action, with a tiny difference in the
equation. And although I had used pow(x,4) before, too, I was unsure about
it causing any changes the original equation. I still don't know why I was
subtracting it from zero in the isosurface in my other reply! Something I
picked up from other people, I think.  :-D
global_settings {
  assumed_gamma 1.0
  photons {
   spacing 0.02
  location  <1, 2, -3>
  look_at   <0, -0.25, 0>
light_source {
 -100*z,
 1
  rotate <10, 0, 0> // move above y plane
  photons {reflection on}
plane {
 y,0
 pigment {color rgb 1}
 finish {diffuse 1}
photons {
 collect on
#declare fn_Xb = function (x,z){0.5*pow(x,4) - x*x - y*y - z*z + 0.9}
isosurface {
  function { (fn_Xb(x,z))-0.1}
  contained_by { box {<-1,0,-1>,<1,0.5,0>} } // get half z, quarter y
  accuracy 0.001
  max_gradient 2
  all_intersections
  open
  pigment{color rgb 0}
  finish {reflection {0.99}}
  photons {target 1 reflection on collect on}
This could be considered the blind leading the blind, eh?
Bob H.
http://www.3digitaleyes.com
Date: 17 Feb 2004 19:30:58
Message: <4032b242@news.povray.org>
-0.1, 0.1 renders even faster! ;)
Like you, I don't know how much of the shape is of interest - I just
kept bumping up the container until I got bored with the
render-speed/max_gradient (I have a vague theory that as long as the mg
keeps increasing, you haven't reached the de facto boundary of the
shape's interest - but this based on intuition rather than knowledge).
As you say - it's hard to know what shape is expected....
Date: 17 Feb 2004 19:40:39
Message: <4032b487$1@news.povray.org>
"Tom Melly" <pov### [at] tomandlucouk> wrote in message
news:4032b242@news.povray.org...
I bet it does.  LOL  Don't raise that max_gradient to 1000, too, though.
Date: 21 Feb 2004 00:56:24
Message: <4036f308@news.povray.org>
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:X7A### [at] econymdemoncouk...
I'm replying back here because I lost track of where I had said a certain
isosurface I was suggesting to someone might not work with this particular
trick. Well, I was wrong. Mike William's has a great resource there, as many
of you already know. I ought to use it more.
Bob H.
