POV-Ray : Newsgroups : povray.newusers : Don't understand "right" Server Time
11 Apr 2026 01:55:44 EDT (-0400)
  Don't understand "right" (Message 1 to 4 of 4)
Subject: Don't understand "right"
Date: 13 Feb 2004 23:10:53
Message: <402d9fcd$1@news.povray.org>
I render an image with a man, his elbow just falling off screen.
right is 115*x.
I rerender with right 125*x  and the amount of elbow falling off screen does
not change.
Subject: Re: Don't understand "right"
Date: 13 Feb 2004 23:17:20
Message: <402da150$1@news.povray.org>
Uh, I had an "angle" statement in there afterwards.  Am trying again without
it....
"Greg M. Johnson" <gregj;-)565### [at] aolcom> wrote in message
news:402d9fcd$1@news.povray.org...
> right is 115*x.
does
> not change.
Date: 14 Feb 2004 01:05:29
Message: <402dbaa9$1@news.povray.org>
news:402da150$1@news.povray.org...
without
> it....
> > right is 115*x.
> does
> > not change.
Right is used to specify the aspect ratio of the viewplane. In other words,
coupled with "up", it keeps those spheres from looking squashed or
stretched. If you always want an accurate picture no matter what your width
and height is, use:
up y
right image_width / image_height * x
Change your angle (like you said) to affect how much of the view the camera
is taking in. I personally like to use the DVD standard aspect ratio for my
stuff. I have found that angle 45 works good to keep the stuff on the left
and right of the frame from getting warped.
Date: 15 Feb 2004 07:39:09
Message: <402f686d@news.povray.org>
> not change.
  It widens/narrows the image sidewise so that the amount of scenery
seen changes in the vertical direction.
  I think that if you want to change the horizontal viewing area you
should change 'up' instead.
