POV-Ray : Newsgroups : povray.newusers : POVRAY for optics and design Server Time
17 Jun 2026 20:55:48 EDT (-0400)
  POVRAY for optics and design (Message 1 to 2 of 2)
Subject: POVRAY for optics and design
Date: 21 Jan 2004 20:50:48
Message: <400f2c78@news.povray.org>
Hi there...I really love this app. I've been using computers for 35 years,
and it's been
a long time since I've wanted to go over every speck of the docs, and get
into all the
dark corners.
I have a couple of newbie questions, though, that I haven't had much luck
finding answers
for:
1) Pointers (links, etc) to info and approaches for using POV-Ray as a
virtual optics
    bench. Not asking the app to perfectly model optics--I just want to do
simple stuff. Example:
    I'm converting a parabolic satellite dish into a solar collector. I want
to place a secondary
    reflector just short of the focal point, and redirect the resulting beam
down through the
    axis of rotation. So this is all front-surface reflection, and I'd like
to look at the result of
    SORs for the secondary reflector before building something. I think I
can create an array
    of multiple-parallel-beam light sources (array of laser beams), so I can
look at the path of
    each beam through the system.
    So in this context (other than requesting general info on optics
projects in POV-Ray), is
    there a way to "blow smoke" in the air to see each beam without
attenuating it?
2) This is the more serious question. I'd like to model an object (for
example, the union of
    two extruded splines that are centered and parallel to the z-axis), take
cross-sections of
    the object at intervals, and read each cross-section out into a file so
the dataset can be converted
    into commands for a numerical-control milling machine. This is more for
artistic applications,
    so extreme precision isn't needed.
    So far, I've discovered only two possible methods, both of which are a
little kludgy:
    -- Derive the union of the shape and an intersecting plane, and using a
parallel light source
    project the slice onto a "screen" of sorts that is coincident with the
POV of the camera. Save
    the bitmap, and then use a conversion utility to read out the outline.
Very kludgy, but creative, no?
    -- Use POV-Ray's _inside_ function to determine if a given point is
inside or outside the
    object. Use an interative routine that "scans" along an array of XY
points on each z-plane
    cross-section, and then by successive approximation generate a series of
points that are
    just inside (or outside) the surface up to some limit of accuracy.
    I can see that I can generate a mesh, save the surface to a file, and
take cross-sections of that
    dataset, but I was wondering if there was a more generalized method one
could use with any
    given union of objects.
Thanks for at least reading this far! 8)
--Chris
Subject: Re: POVRAY for optics and design
Date: 18 Mar 2004 20:14:42
Message: <405a4982$1@news.povray.org>
MVSmith nous apporta ses lumieres ainsi en ce 2004/01/21 20:50... :
>and it's been
>into all the
>dark corners.
>finding answers
>for:
Possible using "photons" and scathering media. Set the media to zero
absorbtion and set some scathering. The render will take a long time as
both photons and media will add a lot of computation. (look at
"optics.pov" in scenes/advanced)
>virtual optics
>down through the
>can create an array
>look at the path of
>attenuating it?
Look for "trace.pov" in scenes/language. It use the "math.inc" library.
It contain a function that return the intersection point of an object
and a vector.
>cross-sections of
>little kludgy:
>points that are
>could use with any
>--Chris
