POV-Ray : Newsgroups : povray.newusers : Stuck with circle-maths Server Time
18 Jun 2026 02:03:10 EDT (-0400)
  Stuck with circle-maths (Message 1 to 4 of 4)
Subject: Stuck with circle-maths
Date: 20 Oct 2003 20:00:52
Message: <3f947734$1@news.povray.org>
Hi there,
I'm a bit stuck at the moment on a problem that requires some circular
thinking ;)
I have a point A which lies on the circumference of a circle (oriented x-z
like a default torus).
I need point B to lie on the circle as well, but a fixed distance above it.
I have found various solutions using my somewhat dusty trig memory, but they
all fall down in various cases.
If my explanation is a bit vague, render the bit of scene at the end of the
message.
I know the location of the red point. I know the length of the yellow bar.
I can't find the coord for the green point.
(The the red point will never be in such a location that Spot+Bar > Radius)
union{torus{10,0.3} cylinder{-10*x, 10*x, 0.3} cylinder{-10*z, 10*z,
0.3}pigment{color rgb 1}}
sphere{0,1 pigment{color red 1} translate vrotate(10*x, 75*y)}
sphere{0,1 pigment{color green 1} translate vrotate(10*x, 28*y)}
cylinder{0,5*z,0.5 pigment{color rgb<1,1,0>} translate vrotate(10*x, 75*y)}
cylinder{5*z,<5.9,0,5>,0.5 pigment{color rgb<0,0,1>} translate vrotate(10*x,
75*y)}
global_settings{ambient_light color rgb 1}
light_source{<-20, 40, -20> color rgb 1}
camera{location 30*y look_at 0}
Subject: Re: Stuck with circle-maths
Date: 20 Oct 2003 20:44:18
Message: <Xns941B1BD7940E6torolavkhotmailcom@204.213.191.226>
"Mark Hanford" <pov### [at] hanfordonlinecouk> wrote in
news:3f947734$1@news.povray.org:
> Hi there,
> thinking ;)
> x-z like a default torus).
> above it. I have found various solutions using my somewhat dusty trig
> memory, but they all fall down in various cases.
> of the message.
> bar. I can't find the coord for the green point.
> Radius)
Mark, below is some code for you to play with.
Tor Olav
#version 3.5;
#declare Radius = 10;
#declare SphRad = 0.5;
#declare CylRad = SphRad/2;
union {
  torus { Radius, CylRad }
  cylinder { -Radius*x, Radius*x, CylRad }
  cylinder { -Radius*z, Radius*z, CylRad }
  pigment { color White }
#declare pRed = Radius*vrotate(x, 75*y);
#declare YellowLength = 5;
#declare GreenZ = pRed.z + YellowLength;
#declare GreenSin = GreenZ/Radius;
#declare GreenAngle = asin(GreenSin);
#declare GreenX = Radius*cos(GreenAngle);
#declare pGreen = <GreenX, 0, GreenZ>;
#declare pCyan = pRed + YellowLength*z;
sphere { pRed, SphRad pigment { color Red } }
sphere { pGreen, SphRad pigment { color Green } }
sphere { pCyan, SphRad pigment { color Cyan } }
cylinder { pRed, pCyan, CylRad pigment { color Yellow } }
cylinder { pCyan, pGreen, CylRad pigment { color Blue } }
light_source { <-20, 40, -20> color White }
  location 30*y
  look_at 0*y
background { color Gray30 }
Date: 21 Oct 2003 05:12:00
Message: <3f94f860$1@news.povray.org>
"Tor Olav Kristensen" <tor_olav_kCURLYAhotmail.com> wrote in message
> Tor Olav
> #version 3.5;
> union {
> camera {
>   location 30*y
>   look_at 0*y
Thank you very much, Tor!
You've done in four lines what I'd already failed at using 20 :)  My basic
geometry is rather rusty (why am I using POV again?) and that cripples me
fairly often.
If only I'd listened more at school... (in my defence, that was a while ago)
many thanks
Mark
Date: 21 Oct 2003 05:21:56
Message: <3f94fab4$1@news.povray.org>
// Hi Mark,
// no trig is neccessary, only Pythagoras,
// as you can see in the following scene!
//    Sputnik
// parameters of the problem
#declare RedAngle = 75;
#declare Dist = 5; // or whatever
// find coordinates of position of red point
#declare RedPoint = vrotate ( Radius*x, RedAngle*y );
#declare RedX = RedPoint.x;
#declare RedZ = RedPoint.z;
// calculate z of green point
#declare GreenZ = RedZ+Dist;
// calculate x of green point
// (Pythagoras in triangle <0,0,0>, <GreenX,0,0>, <GreenX,0,GreenZ>)
#declare GreenXsquared = Radius*Radius - GreenZ*GreenZ;
#if (GreenXsquared>=0)
    #declare GreenX = sqrt( GreenXsquared );
    // -GreenX also is a solution
  #else
    // no solution
    #error "No solution possible!\n"
#declare GreenPoint  = <GreenX, 0, GreenZ>;
#declare CylJunction = <RedX  , 0, GreenZ>;
// draw everything
union {
  torus { Radius, 0.3 }
  cylinder { -Radius*x , Radius*x, 0.3 }
  cylinder { -Radius*z , Radius*z, 0.3 }
  cylinder { GreenPoint, 0       , 0.3 }
  cylinder { GreenPoint, GreenX*x, 0.3 }
  pigment { color rgb 1 }
sphere { RedPoint  , 1 pigment { color red   1 } }
sphere { GreenPoint, 1 pigment { color green 1 } }
cylinder { RedPoint  , CylJunction, 0.5 pigment { color rgb <1,1,0> } }
cylinder { GreenPoint, CylJunction, 0.5 pigment { color blue 1      } }
// look at all this
light_source { <-20, 40, -20> color rgb 1 }
camera { location 30*y look_at 0 }
// that's all!
