POV-Ray : Newsgroups : povray.newusers : Multiple Objects Server Time
18 Sep 2025 16:42:19 EDT (-0400)
  Multiple Objects (Message 1 to 6 of 6)
Subject: Multiple Objects
Date: 18 Sep 2003 13:09:04
Message: <3f69e6b0@news.povray.org>
I've created a pool ball in POV using a sphere & cylinder and using the
difference & intersection commands to make my Ball "wrapper" and Ball
"core."  See below for sample code.  How can I easily create a second ball
that's blue without copying the current code and making adjustments
accordingly?  I know how to create a second ball and move it around, but I
want to be able to change the color of the wrapper.  Also each ball will
have a number and I would like to be able to change that easliy.
        location <2, 2, -15>
        look_at <2, -2, -2>
light_source {
        <-50,100,-75>
        rgb <1,1,1>
        spotlight
        radius 50
background {
        rgb <1,1,1>
#declare ObjectSphere = sphere {
 <0,0,0>, 2
 finish {
  ambient .25
#declare ObjectCylinder = cylinder {
 <0,0,0>+2*z, <0,0,0>-2*z, 2/3
#declare BallWrapper = difference {
 object {
  ObjectSphere
  pigment { rgb <1,0,0> }
 object { ObjectCylinder }
#declare BallCore = intersection {
 object {
  ObjectSphere
  pigment { rgb <1,1,1> }
#declare ObjectBall = union {
 object { BallWrapper }
 object { BallCore }
object { ObjectBall }
Thanks for any help!
Subject: Re: Multiple Objects
Date: 18 Sep 2003 15:09:13
Message: <3f6a02d9$1@news.povray.org>
See my #declare/Object coloring question for a partial solution, for
creating copies for your balls, dont know about the numbering though.
Date: 18 Sep 2003 16:39:25
Message: <3f6a17fd$1@news.povray.org>
The Macro works great!  Now if I want a new ball, I just type:
CreateBall (Color, Location, Striped (T or F), "Number or Letter")
I've got to figure out how to get the width of my Letter/Number and center
that on the dot.  Thanks.
Date: 18 Sep 2003 18:17:07
Message: <3f6a2ee3$1@news.povray.org>
// Hi Kevin!
// Here follows a ball macro which might do what you need.
//   Sputnik
// Pool Ball
#macro PoolBall (Radius, Color, Number)
#local PoolBallFinish = finish {
  ambient .3
  diffuse .7
  specular .3 roughness 0.01
  reflection .2
union {
  // main sphere
  sphere { 0, Radius
    pigment { color Color }
    finish { PoolBallFinish }
  // core
  intersection {
    cylinder { -Radius*z, Radius*z, .65*Radius }
    sphere { 0, Radius*1.001 } // slightly larger radius to
                               // avoid coincident surfaces
    pigment { color rgb 1 }
  #if (Number>0)
    // number
    #local Num = text { ttf "arial.ttf" str(Number,0,0) Radius/4, 0 }
    #local Num = intersection {
      object { Num
        translate -max_extent(Num)/2 // center around origin
        scale 1.2*Radius // make bigger
        translate -Radius*z // transfer to surface of ball
      sphere { 0, Radius*1.002 } // slightly larger radius to
      pigment { color rgb 0.2 }
    // number on -z side
    object { Num }
    // number on +z side
    object { Num rotate 180*y}
    #end//if
  // no "}" to allow for application of modifiers
  #end//macro Ball
// put a ball into the scene
PoolBall (2, rgb <.8, .2, .1>, 4) /*{*/ rotate 30*z translate 2*y}
// one more ball; don't know if colors match numbers
PoolBall (0.8, rgb <.2, .2, .8>, 5) /*{*/ rotate <50, -70, 0>
  translate <-2, 0.6, -2.5> }
// small ball without number
// (of course a simple sphere would suffice)
PoolBall (1.2, rgb 1, 0) /*{*/ translate <3, 0.6, -1.5> }
// reflecting balls need a checkered plane to survive ...
plane { y, 0
  pigment { checker color green .6 color green .55 }
  finish { ambient .3 diffuse .7 }
light_source { <-2, 3, -1>*10, color rgb 1 }
camera { location -20*z look_at 0 angle 25 rotate <30, -20, 0>
  translate 1*y }
Date: 19 Sep 2003 18:28:41
Message: <cjameshuff-5563E7.18271319092003@netplex.aussie.org>
In article <3f69e6b0@news.povray.org>,
You've already been told about macros, but you might also look at the
object pattern. There's no need to use anything more than a sphere for a
pool ball.
http://tag.povray.org/
Date: 23 Sep 2003 13:14:43
Message: <3f707f83$1@news.povray.org>
Thanks for everyone's help.  Here's the end result:
http://www.kingswoodhomes.com/images/cgbilliards.jpg
