POV-Ray : Newsgroups : povray.newusers : #declare/Object coloring question Server Time
18 Jan 2026 03:28:48 EST (-0500)
  #declare/Object coloring question (Message 1 to 7 of 7)
Subject: #declare/Object coloring question
Date: 17 Sep 2003 14:54:17
Message: <3f68add9$1@news.povray.org>
Here's what I have:
//start
#declare MyTorus = union {
         #while (I<N)
                 torus {2,0.1 rotate <90,0,0> rotate<0, I*360/N,0>}
                 #declare I=I+1;
         light_source{<0,1,1> rgb <1,0.75,0>}
                         color rgb <0.8,0.8,1.0>
                 finish{
                         diffuse 0.3
                         ambient 0.0
                         specular 0.6
                         reflection {
                                 0.8
                                 metallic
                         conserve_energy
object{ MyTorus scale<.5,.5,.5> translate<0,1.25,0> }
//end
Is there anyway to chage the MyTorus (yes almost directly from the
examples :)) to allow me to specify what color I want the lightsource in
the object declaration?
Subject: Re: #declare/Object coloring question
Date: 17 Sep 2003 15:09:37
Message: <3f68b171@news.povray.org>
I'm not quiet sure what you're after. The rgb in the
lightsource-brackets describes the Red, Green
and Blue componentes of the lightsource's color.
rgb <1,1,1> is white, rgb<0,0,0> is black.
The rgb in in the pigment-brackets belongs to
all torii, so changing that will change the color
of the torii.
Aside of that, it might be better to take the lightsource
out of the union and place it into the scene by itself,
unless you're after something specific.
Tim Nikias v2.0
Email: no_lights (@) digitaltwilight.de
> Here's what I have:
> //start
>          #while (I<N)
>                  #declare I=I+1;
>          #end
>          texture {
>                  pigment {
>                  finish{
>                          diffuse 0.3
>                          ambient 0.0
>                          specular 0.6
>                          reflection {
>                                  0.8
>                                  metallic
>                          conserve_energy
> //end
Version: 6.0.518 / Virus Database: 316 - Release Date: 11.09.2003
Date: 17 Sep 2003 15:13:31
Message: <3f68b25b$1@news.povray.org>
> of the torii.
What I was going for is that instead of having to put 50 copies of that
in my scene, I could write it once, then use object to make the copies.
   The particular thing I was going after was a different color
lightsource in the middle of each torus. so I could do like:
object{ MyTorus scale<.5,.5,.5> translate<4,1.25,0> Blue }
object{ MyTorus scale<.5,.5,.5> translate<0,1.25,0> Red }
object{ MyTorus scale<.5,.5,.5> translate<-4,1.25,0> Orange}
etc, so that one would have a red lightsource, one blue, and then orange
Date: 17 Sep 2003 15:17:52
Message: <3f68b360$1@news.povray.org>
Hm. Then I'd make it a macro:
#macro MyTorus_Macro(Light_Color)
#declare MyTorus=[...]
[In the lightsource, put "rgb Light_Color"]
object{MyTorus}
MyTorus_Macro(Blue)
MyTorus_Macro(Orange)
If you'd want to move it around, you can just add
another parameter to the macor:
#macro MyTorus_Macro(Light_Color,Position)
object{MyTorus translate Position}
Tim
Tim Nikias v2.0
> > of the torii.
Date: 17 Sep 2003 15:46:51
Message: <3f68ba2b$1@news.povray.org>
> object{MyTorus}
> #end
> MyTorus_Macro(Blue)
> #end
> Regards,
> Tim
Ah, thanks, that works wonderfully :) (yay my (with some help) macro)
Subject: The macro itself :)
Date: 18 Sep 2003 15:11:15
Message: <3f6a0353@news.povray.org>
#declare I=0;
#declare N=10;
         #while (I<N)
                 torus {1,0.1 rotate <90,0,0> rotate<0, I*360/N,0>}
                 #declare I=I+1;
         light_source{<0,.5,.5> rgb Light_Color}
                 finish{
                         diffuse 0.3
                         ambient 0.0
                         specular 0.6
                         reflection {
                                 0.8
                                 metallic
                         conserve_energy
object{ MyTorus scale<.5,.5,.5> translate Position }
//Call the macro with Color,Translate Position
MyTorus_Macro(Blue,<-1,.5,.7>)
MyTorus_Macro(Orange,<1,.5,0>)
Subject: Re: The macro itself :)
Date: 18 Sep 2003 16:45:09
Message: <3f6a1955$1@news.povray.org>
Declaration of MyTorus is not neccessary (and #local instead of
#declare would avoid introduction/overwriting of variables in the
main scene). My favourite method is like this:
#macro MyTorusMacro (LightColor)
#local I = 0;
#local N = 10;
union {
  // ... whatever ...
  // *no* closing brace! This makes application of *all* object
  // modifiers possible in the main scene, even bounded_by, no_image.
  // 'Match Brace' in the Search menu (and human readers) will *not*
  // be irritated by this omission if the brace appears in a comment
  // instead of beeing omitted completely, like in the following line:
  // "}" of union omitted to allow application of modifiers!
#end// macro MyTorusMacro
Call such macros in this way:
MyTorusMacro (Blue) /*{*/ scale ... rotate ... translate ... }
The commented-out opening brace isn't neccessary for parsing but
avoids irritation of 'Match Brace'. Normally I would call it a
bug to match a brace within a comment or inside a string with a
brace outside; in this case although I'm quite happy with this
behaviour.
   Sputnik
