POV-Ray : Newsgroups : povray.newusers : Spherical board. Server Time
18 Sep 2025 14:38:09 EDT (-0400)
  Spherical board. (Message 1 to 5 of 5)
Subject: Spherical board.
Date: 15 Sep 2003 17:16:28
Message: <3f662c2c@news.povray.org>
I would like to make with POV a non-traditional spherical chess board. I
already have the 1-parametric description of the lines that play the role of
sides of the squares. The intersections of such lines are the corners of the
squares, for which I would like to use two different patterns, of course.
I have some idea about how to do it, but does not seem very practical. Any
suggestions?
Thanks in advance.
Universidad Complutense de Madrid
Avda. Complutense s/n
28040 Madrid
Tlf. 91 394 44 11
Subject: Re: Spherical board.
Date: 16 Sep 2003 04:12:38
Message: <3f66c5f6@news.povray.org>
The easiest way to do that depends a bit upon the exact geometry of your
squares. So you should precise a bit.
Until some specialist answers you, I can give some tracks:
- You can combine a radial and gradient textures.
- You can use UV mapping I think, but I don't know much on how to use it.
- You can generate your sphere as a mesh and assign the proper texture
to each triangle.
I would go with the first one, it is probably the easiest and more
efficient solution. Let me know if you need more clues,
JC
> suggestions?
> Thanks in advance.
> 28040 Madrid
> Tlf. 91 394 44 11
Date: 16 Sep 2003 04:20:10
Message: <3f66c7ba@news.povray.org>
Is that what you want ?
#declare T_G1=texture {
     gradient y
     color_map {
       [0.0 rgb 1.0]
       [0.5 rgb 1.0]
       [0.5 rgb 0.0]
       [1.0 rgb 0.0]
     scale 1/4
#declare T_G2=texture {
   T_G1
   translate <0,1/8,0>
sphere {
   <0,1,0>, 1
     radial
     frequency 4
     texture_map {
       [0.0 T_G1]
       [0.5 T_G1]
       [0.5 T_G2]
       [1.0 T_G2]
> suggestions?
> Thanks in advance.
> 28040 Madrid
> Tlf. 91 394 44 11
Date: 16 Sep 2003 06:12:19
Message: <3f66e203$1@news.povray.org>
"JC (Exether)" <no### [at] spamfr> wrote in message
news:3f66c5f6@news.povray.org...
I never heard about it, so I will take a look at it.
> to each triangle.
You are right, I did not think about it. But this is the last thing that I
will try.
Thanks a lot for your ideas.
http://www.telefonica.net/web/miguelgdz/index.html
Date: 16 Sep 2003 06:15:49
Message: <3f66e2d5$1@news.povray.org>
news:3f66c7ba@news.povray.org...
>    pigment {
>      gradient y
>      color_map {
>        [0.0 rgb 1.0]
>        [0.5 rgb 1.0]
>        [0.5 rgb 0.0]
>        [1.0 rgb 0.0]
>      scale 1/4
>    T_G1
>    translate <0,1/8,0>
> sphere {
>    <0,1,0>, 1
>    texture {
>      radial
>      frequency 4
>      texture_map {
>        [0.0 T_G1]
>        [0.5 T_G1]
>        [0.5 T_G2]
>        [1.0 T_G2]
Well, no. This is a traditional spherical squared board. I have a different
geometry in mind, where the sides of the squares are not the classical
meridians and paralels. I have the equations of such lines, but nothing
else.
Thanks again.
