POV-Ray : Newsgroups : povray.newusers : Filters With Texture Server Time
21 Nov 2025 07:37:45 EST (-0500)
  Filters With Texture (Message 1 to 6 of 6)
Subject: Filters With Texture
Date: 12 Aug 2003 19:44:53
Message: <3f397bf5$1@news.povray.org>
Here's my code:
difference {
         box {
                 <-2, -1, 0.1>, <2, 1, 1>
                 texture { T_Stone10
                           color filter clock }
         text {
                 ttf "timrom.ttf" "Text" 0.15, 0
                 pigment { BrightGold
                 finish { reflection .25 specular 1 }
                 translate -1.05*x
Which is What I want to do, but isnt' valid.  What I'm trying to do is
change the transparency of the objects for an animation so they fade in
over the course of the animation. clock goes from 0 to 1.
Subject: Re: Filters With Texture
Date: 12 Aug 2003 22:00:06
Message: <UPM5dFA1pZO$EwGJ@econym.demon.co.uk>
Wasn't it Brent G who wrote:
>Here's my code:
>difference {
>         box {
>                 texture { T_Stone10
>         text {
>                 translate -1.05*x
1. For a plain colour like BrightGold, a valid syntax is like this:
         text {
                 #declare CFC = color filter clock;
                 pigment { BrightGold  + CFC }
                 translate -1.05*x
2. For a complicated texture like T_Stone10 you can't apply filter to
   the whole thing. What you'd have to do is take a copy of the
   T_Grnt3a, T_Grnt17a and T_Stone10 declarations from stones1.inc and
   change all the rgbt colours into rgbft, inserting "clock," as the
   fourth component, like this:
   #declare T_Grnt3a =
   pigment
    {granite
     turbulence 0.6
     color_map
      {[0.000, 0.153   color rgbft <0.831, 0.631, 0.569, clock, 0.447>
                       color rgbft <0.925, 0.831, 0.714, clock, 0.678>]
       [0.153, 0.297   color rgbft <0.925, 0.831, 0.714, clock, 0.678>
                       color rgbft <0.871, 0.702, 0.659, clock, 0.475>]
       [0.297, 0.441   color rgbft <0.871, 0.702, 0.659, clock, 0.475>
                       color rgbft <0.831, 0.631, 0.569, clock, 0.918>]
       [0.441, 0.763   color rgbft <0.831, 0.631, 0.569, clock, 0.918>
                       color rgbft <0.937, 0.882, 0.820, clock, 0.655>]
       [0.763, 1.001   color rgbft <0.937, 0.882, 0.820, clock, 0.655>
                       color rgbft <0.831, 0.631, 0.569, clock, 0.447>]
3. However, this doesn't cause the object to fade in during the course
   of the animation. That's not what "filter" does, you are probably
   thinking of "transmit". This is particularly noticeable in the case
   of the Black layer of T_Stone10. When the layer is "Black + filter 0"
   it is opaque and black. When the layer is "Black + filter 1" then
   light is considered to pass through the object, but on the way
   through the colour of the light is changed to being completely black.
You can easily do the plain colour with transmit, but the layers of that
stone texture already contain some transmit. So you'd have to modify
them so that the transmit varies from the initial value when clock=0 to
1 when clock=1, something like this:
#declare T_Grnt3a =
pigment
 {granite
  turbulence 0.6
  color_map
   {[0.000, 0.153   color rgbt <0.831, 0.631, 0.569, 0.447+0.553*clock>
                    color rgbt <0.925, 0.831, 0.714, 0.678+0.322*clock>]
    [0.153, 0.297   color rgbt <0.925, 0.831, 0.714, 0.678+0.322*clock>
                    color rgbt <0.871, 0.702, 0.659, 0.475+0.535*clock>]
    [0.297, 0.441   color rgbt <0.871, 0.702, 0.659, 0.475+0.535*clock>
                    color rgbt <0.831, 0.631, 0.569, 0.918+0.082*clock>]
    [0.441, 0.763   color rgbt <0.831, 0.631, 0.569, 0.918+0.082*clock>
                    color rgbt <0.937, 0.882, 0.820, 0.655+0.545*clock>]
    [0.763, 1.001   color rgbt <0.937, 0.882, 0.820, 0.655+0.545*clock>
                    color rgbt <0.831, 0.631, 0.569, 0.447+0.553*clock>]
Mike Williams
Gentleman of Leisure
Date: 12 Aug 2003 22:13:24
Message: <3F39A03B.7B258FF2@pacbell.net>
Brent G wrote:
> Here's my code:
> difference {
>          box {
>                  texture { T_Stone10
>          text {
>                  translate -1.05*x
In the box object statement you are trying to filter a predeclared texture
which in not allowed in POV-Ray. You have to apply the filter to the individual
pigments in the color_map for T_Stone10 in stones1.inc or copy it to your
working scene file and modify it there. You have to remember that the stone
textures are layered so you may have to adjust the filter amounts to get the
effect you are looking for.
Below is an untested example to get you started.
#declare T_Grnt3a =
pigment
 {granite
  turbulence 0.6
  color_map
   {[0.000, 0.153   color rgbt <0.831, 0.631, 0.569, 0.447*clock>
                    color rgbt <0.925, 0.831, 0.714, 0.678*clock>]
    [0.153, 0.297   color rgbt <0.925, 0.831, 0.714, 0.678*clock>
                    color rgbt <0.871, 0.702, 0.659, 0.475*clock>]
    [0.297, 0.441   color rgbt <0.871, 0.702, 0.659, 0.475*clock>
                    color rgbt <0.831, 0.631, 0.569, 0.918*clock>]
    [0.441, 0.763   color rgbt <0.831, 0.631, 0.569, 0.918*clock>
                    color rgbt <0.937, 0.882, 0.820, 0.655*clock>]
    [0.763, 1.001   color rgbt <0.937, 0.882, 0.820, 0.655*clock>
                    color rgbt <0.831, 0.631, 0.569, 0.447*clock>]
#declare T_Grnt17a =
pigment
 {granite
  turbulence 0.6
  color_map
   {[0.000, 0.034   color rgbt <0.027, 0.012, 0.012, 0.000*clock>
                    color rgbt <0.851, 0.812, 0.741, 0.235*clock>]
    [0.034, 0.342   color rgbt <0.851, 0.812, 0.741, 0.235*clock>
                    color rgbt <0.792, 0.694, 0.690, 0.839*clock>]
    [0.342, 0.462   color rgbt <0.792, 0.694, 0.690, 0.839*clock>
                    color rgbt <0.631, 0.506, 0.471, 0.608*clock>]
    [0.462, 0.632   color rgbt <0.631, 0.506, 0.471, 0.608*clock>
                    color rgbt <0.851, 0.812, 0.741, 0.922*clock>]
    [0.632, 0.983   color rgbt <0.851, 0.812, 0.741, 0.922*clock>
                    color rgbt <0.647, 0.655, 0.655, 0.282*clock>]
    [0.983, 1.001   color rgbt <0.647, 0.655, 0.655, 0.282*clock>
                    color rgbt <0.027, 0.012, 0.012, 0.000*clock>]
#declare T_Stone10 =
texture{pigment{color Black*clock}}
texture{T_Grnt17a scale <3, 6, 2> rotate <0, 0, 50>}
texture{T_Grnt3a scale <1, 2, 1> rotate <0, 0, -50>
        finish{phong 1.0 phong_size 90}
In the text object, if you remove the 'color' keyword, it will work as is.
Ken Tyler
Date: 12 Aug 2003 22:25:11
Message: <3f39a187$1@news.povray.org>
Program ended abnormally on 2003-08-12 22:19, Due to a catastrophic Ken
error:
> texture {
> pigment
>  {granite
>   turbulence 0.6
>   color_map
I think that in this case, he can safely omit multiplying by "clock".
Date: 12 Aug 2003 22:32:12
Message: <3F39A4A4.E5BE5829@pacbell.net>
Well, I said some modifications might be necessary... ...didn't I?
Ken Tyler
Date: 13 Aug 2003 00:12:11
Message: <VtWZ1DAfpbO$Ewk7@econym.demon.co.uk>
>Here's my code:
>difference {
>         box {
>                 texture { T_Stone10
>         text {
>                 translate -1.05*x
I just found a neat trick for dealing with complicated textures like
T_Stone10. Take an average of T_Stone10 with Clear, varying the ratios
of the two component textures as the clock changes.
         box {
                   average
                   texture_map {
                     [clock   T_Stone10]
                     [1-clock pigment {Clear}]
Mike Williams
