![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi, can the slope pattern be used with a slope_map? The docs say:
"A slope_map may be used with any pattern except brick, checker, object,
hexagon, bumps, dents, ripples, waves, wrinkles and bump_map."
So it should work? But the following piece of code doesn't give any kind of
ramp:
camera{location<0,0,-5>
look_at<0,0,0>}
light_source{<-10,10,-50>color White*2}
#declare Slopenormal= normal{slope{<0,-1,0>,0,1}
slope_map{[0 <1,0>]
[.4 <1,-1>]
[.5 <0,0>]
[1 <0,0>]} }
sphere{<0,0,0>,1 pigment{color Grey}
normal{Slopenormal}}
If I understand this correctly this should give me a ramp down somewhere
little above the middle of the sphere.
What am I missing?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It is mathematically possible, but that is also the case for bumps,
dents, ripples, waves, wrinkles, and bump_map...these are all "special"
normal patterns. They used to be normal-only patterns, and behave
slightly differently in normals. (The brick, checker, object, and
hexagon patterns just aren't useful at all for normal patterns...they
have abrupt changes between values, rather than smooth gradients.)
The slope pattern is not part of this group, but does require extra
information to compute...such as the perturbed normal, which is what it
is being used to compute. In other words, the slope pattern is affected
by the normal, and when it is used as the normal, it tries to use stuff
that hasn't been fully computed yet. This could be fixed...I'll bring it
to the attention of the POV Team.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
OK thanks, its great you POV gurus take time to sort newbie problems!
On the matter of slopes again,
its also not possible to translate or rotate the slope pattern or to use it
as a function, I guess.
I'm just going through the POV-Ray docs trying to learn as much as possible.
Right now the idea of using functions as patterns and the whole idea of 3D
solid texturing seems the most confusing to me.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3f35342b@news.povray.org>, "JK" <bil### [at] mbnet fi> wrote:
> On the matter of slopes again, its also not possible to translate or
> rotate the slope pattern or to use it as a function, I guess.
Correct. It requires information about a surface normal, instead of just
position as with most other patterns.
Well, consider a real-world sphere being carved from a block of wood.
The grain and ring structure exist through the entire block of wood, as
you carve out the sphere you only this structure at the surface. In POV,
this structure is usually defined with a 3D function. The gradient
pattern is an infinite stack of gradients, the wood pattern is similar,
but based on nested infinite cylinders instead. You describe the
materials objects are made of, instead of stretching images over their
surfaces.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
