POV-Ray : Newsgroups : povray.newusers : problems with rand Server Time
12 Jul 2026 07:43:44 EDT (-0400)
  problems with rand (Message 1 to 2 of 2)
Subject: problems with rand
Date: 29 Jul 2003 19:59:45
Message: <3f270a71$1@news.povray.org>
I want to place tree rows along the z axis. Trees should be rotated
randomly, but each tree pair (trees that are located in Pos and 0-Pos)
should have same amount of rotation.
Currently following code doesn't do that; All of the trees are rotated with
equal values. My guess is that for some reason RdmC isn't updated when it's
called by RA.
Question: Why this xxxxxxx code doesn't work?
Sorry if I offended anyone. I guess i'm a little bit tired. I'm writing this
at 3.21 AM and should be at work by 8.00.
Hmm, maybe I should join POVoholics Anonymous :) :) Anyway here's the code:
#include "rand.inc"
#while(A<Loop)
#declare RP=VRand_In_Box(<-1,4.9,-5>,<1,5,-5> , RdmA);
#declare Pos=trace(Lightside, <RP.x,100,RP.z>,<0,-1,0>,Norm);
#declare RA=RdmC;
object{ TREE scale 0.12 rotate y*360*RA translate Pos}
object{ TREE2 scale 0.12 rotate y*360*RA translate <Pos.x, Pos.y, 0-Pos.z>}
#declare A=A+1;
Thanks
Janne
Subject: Re: problems with rand
Date: 29 Jul 2003 21:04:15
Message: <Z3Q6TCAYlxJ$Ew80@econym.demon.co.uk>
Wasn't it Janne who wrote:
>Hi,
>called by RA.
>#declare RA=RdmC;
RdmC is the *seed* of a random number stream. To get a random number
from that stream you should write
#declare RA=rand(RdmC);
Mike Williams
Gentleman of Leisure
