POV-Ray : Newsgroups : povray.newusers : difficult problem with lights Server Time
12 Jul 2026 09:17:24 EDT (-0400)
  difficult problem with lights (Message 1 to 10 of 12)
Subject: difficult problem with lights
Date: 15 May 2003 18:17:59
Message: <3ec41217$1@news.povray.org>
I am a very new POV-ray user and am a little hesitant about asking such
a basic question.  I have been trying different practice pieces and
everything works except lights.  I have a picture at
http://www.ccbrundage.net/save/image2.jpg - the cross is supposed to be
shiny gold but no matter what I do, I can't get a light to shine on it.
I have had this trouble with all my pictures.  I have tried every type
of light, location, etc.  I would appreciate any suggestions - I would
like the light to shine from the left - but anywhere is ok now!!!
Many thanks in advance,
Christina B.
http://www.ccbrundage.net/saints/
http://web.tampabay.rr.com/ccb/
http://www.thecelticplanet.com/
Download 'iso-8859-1' (2 KB)
Subject: Re: difficult problem with lights
Date: 15 May 2003 18:29:04
Message: <3ec414b0@news.povray.org>
Christina B. wrote:
> I am a very new POV-ray user and am a little hesitant about asking such a
> shiny gold but no matter what I do, I can't get a light to shine on it.  I
> have had this trouble with all my pictures.  I have tried every type of
> light, location, etc.  I would appreciate any suggestions - I would like
> Christina B.
Nice picture.
It looks like you haven't actually declared a texture or a pigment for the
cross, I mean if you don't declare a pigment or a texture for an object,
it will look black. Are you sure you have a gold texture active?
Bill Hails
Date: 15 May 2003 21:18:50
Message: <3ec43c7a@news.povray.org>
Posting the scene file in question would help finding the problem in
this case.
  Let me introduce a rather technical explanation about how objects "shine"
when light hits them and how this is achieved in a renderer like POV-Ray.
  It's clear that light reflects from objects and that's why we see these
objects in the first place. However, this is a simplification. Light can
reflect from the surface of an object in different ways depending on the
properties of the surface.
  In a simplified lighting model (which is usually enough for making
good-looking images) there are two ways light can reflect from a surface:
Diffusely and specularly.
  Diffuse reflection assumes the surface is extremely rough at microscopic
level and thus reflects light equally to all directions (all directions
that can be seen from the surface, naturally). Less-technical synonyms for
a diffuse surface are "matte" and "dull". The brightness of the surface
is not dependent on the direction you are looking at it.
  Specular reflection assumes a very smooth surface, with little roughness,
which causes light to be reflected mostly like a mirror does. The brightness
of the surface is highly dependant on where do you look at it from: If
the light is reflected directly at your eye, you see a bright spot at
that place in the surface.
  Since most real-life surfaces are not purely diffuse nor specular, but
something in between, this is simulated by calculating both properties
and adding them together (even though it might not be 100% physically
correct, it gives a result which looks good enough).
  Now, shiny surfaces are shiny because they have a very high specular
property to them. They reflect a lot of light specularly (ie. in the
reflected direction).
  This means that to get a shiny object, you have to specify a high
specular property to it.
  One requirement for the object to look shiny is that light reflects
from its surface to the camera. That is, parts of the surface must be
oriented so that this happens.
  One problem which might arise is if you use objects with sharp edges
and planar (ie. flat) surfaces. There simply might not be any surface on
the object which is oriented correctly to show a shiny highlight.
  Objects in real life have seldom sharp edges and perfectly planar
surfaces. Rounding the edges of your object helps a lot (the specular
highlights will usually appear on the rounded edges because part of
them will have the right orientation). Naturally positioning the camera
and the light source so that they are at the proper angle with respect
to a planar surface of the object will give a (usually big) highlight
on this surface, but that's usually quite artificial (even though
sometimes it gives a great look to the object).
  So from the above technical mumbo-jumbo we can conclude two requirements
to make your object look shiny:
  1. Define a "finish { specular 1 }" (or a variant) in your object.
  2. Round the edges of your object. (This usually requires some modelling
     skills, but that's what rendering is all about.)
Date: 15 May 2003 21:22:46
Message: <3ec43d65@news.povray.org>
Oh, forgot to add this:
  Naturally making the object reflective helps making it look shiny.
That is, the finish-block could look something like
"finish { specular 1 reflection .5 }"
Date: 15 May 2003 23:43:50
Message: <3ec45e76$1@news.povray.org>
I really appreciate your explanation - too bad you didn't write the
documentation!  I didn't catch the difference between diffuse and
specular before.  I will try changing the coding.
Excuse the feeble coding because I have just been doing this this week -
here is what I have now -
So far the cross is still 2 separate boxes - I haven't put them together
yet.  (I'll have to read the documentation for union vs. merge.)  The
coding I have now is -
#declare F_MetalE  =
finish {
    brilliance 6
    diffuse D_GoldE
    ambient A_GoldE
    metallic M
    specular 0.80
    roughness 1/120
box { <.6, .5, 3>, <1.2, .65, 3>
 texture{
  F_MetalE}
  finish
  {ambient .1
 box { <.8, -.4, 3>, <.95, 1, 3>
  texture{
  F_MetalE}
   finish {ambient .1
I haven't yet made the 2 boxes into one object.  I would have been happy
to get any kind of light onto any part of either one of those but no
matter which way  I change the location and look_at of light sources,
they never show up.  I have sometimes seen a little light on the plane
but it doesn't seem to be coming from a direction consistent with my
coding, so obviously I am doing something awfully wrong.  The
documentation isn't really helpful in this for me.
Christina
news:3ec43c7a@news.povray.org...
  this case.
"shine"
POV-Ray.
these
can
the
surface:
microscopic
directions
for
surface
roughness,
brightness
but
on
camera
requirements
modelling
Download 'windows-1252' (7 KB)
Date: 16 May 2003 03:54:17
Message: <6759cvk455r5oif60ddi87fap3m7dvfbq5@4ax.com>
On Thu, 15 May 2003 23:43:46 -0400, "Christina B."
<ccb### [at] tampabayrrcom> wrote:
>I really appreciate your explanation - too bad you didn't write the documentation!
I believe Warp did actually write part of the documentation :)
Anyway, I think you've got the concept of diffuse and ambient just a
tad off. I guess you've used some other 3D applications (probably
OpenGL ones) where you set the color of an object by its diffuse and
ambient _colors_. However, in POV you need to set a _pigment_ to the
object to determine the color of an object. The finish statement more
or less determines the luminance of that color depending on the light
position, incidence angle etc. (it's not so simple of course but at
least that's what diffuse, ambient and brilliance do).
Here's a more or less shiny object in a simple scene:
sphere {
	0,1
		finish {
			ambient 0.1
			diffuse 0.9
			brilliance 1.75
			phong 0.4 phong_size 10
			specular 0.8 roughness 0.005
			reflection 0.125 metallic on
			conserve_energy
		pigment { rgb <0.3,0.6,1> }
light_source { <10,10,-10> color rgb 1 }
  location -4*z
  look_at 0
union {
  box { -1, 1 translate <-1.1,-1.1,0> }
  box { -1, 1 translate <-1.1,1.1,0> }
  box { -1, 1 translate <1.1,-1.1,0> }
  box { -1, 1 translate <1.1,1.1,0> }
  texture { pigment { rgb 1 } finish { ambient 1 } }
  scale <10,20,0.1>
  translate <30,20,-15>
  no_shadow
I hope this helps.
Peter Popov ICQ : 15002700
Date: 16 May 2003 04:32:50
Message: <dd89cvciojd8n8djm087lbrnstbvmm5vd6@4ax.com>
On Thu, 15 May 2003 23:43:46 -0400, "Christina B." <ccb### [at] tampabayrrcom> wrote:
http://www.povray.org/documentation/view/305/
Chapter 9. POV-Ray Questions and Tips
by Warp
ABX
Date: 16 May 2003 15:14:35
Message: <3ec5389b@news.povray.org>
"Christina B." <ccb### [at] tampabayrrcom> wrote in message
news:3ec45e76$1@news.povray.org...
documentation!
Ah, you've opened a can of worms. I'll put the toast on.
Date: 16 May 2003 15:59:17
Message: <3ec54315@news.povray.org>
"Tom & Lu Melly" <all### [at] tomandlucouk> wrote in message
news:3ec5389b@news.povray.org...
  Is that with cheese? I think I'll join you...  ;)
   ~Steve~
Date: 16 May 2003 17:30:36
Message: <3ec55869.195624413@news.povray.org>
Balsamic vinegar with worms, cheese with the things under rocks.
Regards
