POV-Ray : Newsgroups : povray.newusers : difficult problem with lights Server Time
13 Jun 2026 03:39:35 EDT (-0400)
  difficult problem with lights (Message 11 to 12 of 12)
Subject: Re: difficult problem with lights
Date: 17 May 2003 09:40:48
Message: <3ec63be0@news.povray.org>
I'm not a real expert on texturing, but maybe you should remove the
diffuse and ambient statements from the finish. Or at least change their
values to a number (between 0 and 1 i think) instead of D_GoldE and
A_GoldE. It might work, it might not work, but it doesn't hurt trying
it.
Good Luck
JWV
  "Christina B." <ccb### [at] tampabayrrcom> wrote in message
news:3ec45e76$1@news.povray.org...
  I really appreciate your explanation - too bad you didn't write the
documentation!  I didn't catch the difference between diffuse and
specular before.  I will try changing the coding.
  Excuse the feeble coding because I have just been doing this this week
- here is what I have now -
  So far the cross is still 2 separate boxes - I haven't put them
together yet.  (I'll have to read the documentation for union vs.
merge.)  The coding I have now is -
  #declare F_MetalE  =
  finish {
      brilliance 6
      diffuse D_GoldE
      ambient A_GoldE
      metallic M
      specular 0.80
      roughness 1/120
  box { <.6, .5, 3>, <1.2, .65, 3>
   texture{
    F_MetalE}
    finish
    {ambient .1
   box { <.8, -.4, 3>, <.95, 1, 3>
    texture{
    F_MetalE}
     finish {ambient .1
  I haven't yet made the 2 boxes into one object.  I would have been
happy to get any kind of light onto any part of either one of those but
no matter which way  I change the location and look_at of light sources,
they never show up.  I have sometimes seen a little light on the plane
but it doesn't seem to be coming from a direction consistent with my
coding, so obviously I am doing something awfully wrong.  The
documentation isn't really helpful in this for me.
  Christina
  http://www.ccbrundage.net/saints/
  http://web.tampabay.rr.com/ccb/
  http://www.thecelticplanet.com/
news:3ec43c7a@news.povray.org...
      Posting the scene file in question would help finding the problem
in
    this case.
      Let me introduce a rather technical explanation about how objects
"shine"
    when light hits them and how this is achieved in a renderer like
POV-Ray.
      It's clear that light reflects from objects and that's why we see
these
    objects in the first place. However, this is a simplification. Light
can
    reflect from the surface of an object in different ways depending on
the
    properties of the surface.
      In a simplified lighting model (which is usually enough for making
    good-looking images) there are two ways light can reflect from a
surface:
    Diffusely and specularly.
      Diffuse reflection assumes the surface is extremely rough at
microscopic
    level and thus reflects light equally to all directions (all
directions
    that can be seen from the surface, naturally). Less-technical
synonyms for
    a diffuse surface are "matte" and "dull". The brightness of the
surface
    is not dependent on the direction you are looking at it.
      Specular reflection assumes a very smooth surface, with little
roughness,
    which causes light to be reflected mostly like a mirror does. The
brightness
    of the surface is highly dependant on where do you look at it from:
If
    the light is reflected directly at your eye, you see a bright spot
at
    that place in the surface.
      Since most real-life surfaces are not purely diffuse nor specular,
but
    something in between, this is simulated by calculating both
properties
    and adding them together (even though it might not be 100%
physically
    correct, it gives a result which looks good enough).
      Now, shiny surfaces are shiny because they have a very high
specular
    property to them. They reflect a lot of light specularly (ie. in the
    reflected direction).
      This means that to get a shiny object, you have to specify a high
    specular property to it.
      One requirement for the object to look shiny is that light
reflects
    from its surface to the camera. That is, parts of the surface must
be
    oriented so that this happens.
      One problem which might arise is if you use objects with sharp
edges
    and planar (ie. flat) surfaces. There simply might not be any
surface on
    the object which is oriented correctly to show a shiny highlight.
      Objects in real life have seldom sharp edges and perfectly planar
    surfaces. Rounding the edges of your object helps a lot (the
specular
    highlights will usually appear on the rounded edges because part of
    them will have the right orientation). Naturally positioning the
camera
    and the light source so that they are at the proper angle with
respect
    to a planar surface of the object will give a (usually big)
highlight
    on this surface, but that's usually quite artificial (even though
    sometimes it gives a great look to the object).
      So from the above technical mumbo-jumbo we can conclude two
requirements
    to make your object look shiny:
      1. Define a "finish { specular 1 }" (or a variant) in your object.
      2. Round the edges of your object. (This usually requires some
modelling
         skills, but that's what rendering is all about.)
    plane{-x+y,-1pigment{bozo color_map{[0rgb x][1rgb x+y]}turbulence
1}}
    <1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}//  -
Warp -
Download 'windows-1252' (8 KB)
Date: 17 May 2003 09:55:46
Message: <3ec63f62$1@news.povray.org>
And don't forget old cornedbeef that's already a bit green
