POV-Ray : Newsgroups : povray.newusers : keeping texture after CSG Server Time
21 Mar 2026 18:19:52 EDT (-0400)
  keeping texture after CSG (Message 1 to 2 of 2)
Subject: keeping texture after CSG
Date: 10 Mar 2003 11:03:11
Message: <3e6cb73f@news.povray.org>
Hi POV-Ray-experts,
I have problems using cutaway_textures for a CSG difference operation. I
want to cut a blob of spheres (all slightly different colored) with a box.
The spheres are ordered on a 2D-plane and should be flattened on the side
where the box is located. So far so good.
My problem is, that cutaway_textures does not work when performing the
difference between the blob and the box. All the spheres turn completely
black. With cutaway_textures commented out just the flattened side is black.
When I use a simple set of spheres (_without_ a blob surrounding them)
everything is fine, except that I don't have to blob.
Any ideas why POV behaves like that?
Best regards,
Alex
_________________________________
Ale### [at] gmxde
http://www.it99.org/axl
+49 (0) 1 75/ 410 72 68
ICQ# 36765668
Subject: Re: keeping texture after CSG
Date: 10 Mar 2003 15:43:06
Message: <cjameshuff-FBCF3C.15431410032003@netplex.aussie.org>
In article <3e6cb73f@news.povray.org>,
I suspect this is where your problem is. The texture code is full of
little hacks, there are lots of little special-cases to deal with things
like blob component textures and cutaway_textures. Probably something
got missed in writing the cutaway_textures feature.
If you specify a texture for the blob itself, it will probably use that
texture. The obvious flaw with this is that you only get one texture.
http://tag.povray.org/
