POV-Ray : Newsgroups : povray.newusers : How to avoid cracks in Isosurface? Server Time
21 Mar 2026 18:19:52 EDT (-0400)
  How to avoid cracks in Isosurface? (Message 1 to 7 of 7)
Subject: How to avoid cracks in Isosurface?
Date: 8 Mar 2003 10:05:53
Message: <3e6a06d1@news.povray.org>
Hello,
How can I avoid the black cracks in the isosurface?
And how to move the camera in a circular radius movement around
an isosurface object?
Thanks,
H.Frik
Here is the code:
  #include "stones.inc"
  #include "textures.inc"
  #include "shapes.inc"
  #include "woods.inc"
  #include "functions.inc"
 global_settings {
  max_trace_level 20
location <1.3,0.8,5.>
  look_at <0.,0.4,0>
  #declare Lightbulb = union {
    merge {
      sphere { <0,0,0>,1 }
      cylinder {
        <0,0,1>, <0,0,0>, 1
        scale <0.35, 0.35, 1.0>
        translate  0.5*z
        pigment {color rgb <1, 1, 1>}
        finish {ambient .8 diffuse .6}
    cylinder {
      <0,0,1>, <0,0,0>, 1
      scale <0.4, 0.4, 0.5>
      texture { Brass_Texture }
      translate  1.5*z
    rotate -90*x
    scale 0.5
 light_source {
     <5,5,20>
    color White
    looks_like { Lightbulb }
  light_source {
    <5, 50,20>
   color White
  sky_sphere {
      gradient y
      color_map {
        [ 0.5  color CornflowerBlue ]
        [ 1.0  color MidnightBlue ]
      scale 1
      translate -1
#declare F=function{pattern{
  ripples
  scale 0.2
  rotate y*30
  warp{repeat x*0.4 flip x}
#declare P=function{pigment{leopard
   colour_map{[0.0  rgb 0.0]
              [0.3  rgb 0.0]
              [1.0  rgb 1.0]}
   scale 0.1
#declare P1=function{pattern{leopard turbulence 0.3 scale 0.2}}
#declare P2=function{pattern{leopard turbulence 0.3 scale 0.5}}
#declare P3=function  {x*0 + y + z*0}
 isosurface {function { y - P1(x,y*x,z)*0.3 -P2(x,0,z)*1.0+
y - P1(x,y,z)*0.3 - P2(x,0,z)*1.0+
f_noise3d(x,y,z)*0.3}
rotate <0,20,0>
scale 2
 normal {  crackle 0.1 scale .102  }
 normal {  wrinkles 0.001 scale .02  }
  normal { bumps 0.01 scale .02 }// translate <0,0,0>
   T_Stone23 scale <0.35, 0.35, 1.0>}
        scale 3
finish {ambient 0.15 diffuse 0.85 phong 0.2 reflection 0.1} //
pre-defined in finish.inc
 normal {  crackle 0.1 scale .02  }
   fog { fog_type   2
      distance   2.8
   color White
      fog_offset 0.1
      fog_alt    0.2
      turbulence 0.8
Download 'iso-8859-1' (6 KB)
Subject: Re: How to avoid cracks in Isosurface?
Date: 8 Mar 2003 10:22:40
Message: <3e6a0ac0$1@news.povray.org>
In article <3e6a06d1@news.povray.org> , "HFrik" <fri### [at] zonnetnl> wrote:
By simply reading the messages POV-Ray outputs!  They tell you want is wrong
and how to fix it.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 8 Mar 2003 17:25:54
Message: <3e6a6df2$1@news.povray.org>
In many cases, you will need to raise the max_gradient value. Look for a
message (choose Editor/Show Message Window if you can't see them)
indicating how high it should.
Best,
D.
  "HFrik" <fri### [at] zonnetnl> wrote in message
news:3e6a06d1@news.povray.org...
  Hello,
  Thanks,
  H.Frik
  Here is the code:
   global_settings {
    max_trace_level 20
    look_at <0.,0.4,0>
      merge {
        cylinder {
          <0,0,1>, <0,0,0>, 1
          translate  0.5*z
      cylinder {
        <0,0,1>, <0,0,0>, 1
        translate  1.5*z
      rotate -90*x
      scale 0.5
   light_source {
       <5,5,20>
      color White
    light_source {
      <5, 50,20>
     color White
    sky_sphere {
        gradient y
        color_map {
        scale 1
        translate -1
    ripples
    scale 0.2
    rotate y*30
                [0.3  rgb 0.0]
                [1.0  rgb 1.0]}
     scale 0.1
  rotate <0,20,0>
  scale 2
          scale 3
     fog { fog_type   2
        distance   2.8
     color White
        fog_offset 0.1
        fog_alt    0.2
        turbulence 0.8
Date: 9 Mar 2003 04:06:08
Message: <1frjswe.1fiy40culn0b0N%smellenbergh@skynet.be>
In your example you didn't specify a max_gradient.
POV-Ray will therefore use the default max_gradient of 1.1
Check the messages at the end of your render. POV will suggest a better
max_gradient, probably around 3.7
So add
  max_gradient 3.7
in the isosurface block, and the cracks should dissappear.
Since the max_gradient varies a bit throughout this scene, rendering
could be faster when using the adaptive evaluation of the max_gradient.
Instead of max_gradient 3.7, try this:
  evaluate 2.0, 1.1, 0.8
This should render faster and probably without cracks.
e-mail:sme### [at] skynetbe
http://users.skynet.be/smellenbergh
Date: 9 Mar 2003 13:48:01
Message: <3e6b8c61@news.povray.org>
I found it.
Thanks,
H.Frik
Download 'iso-8859-1' (1 KB)
Date: 3 Apr 2003 18:10:22
Message: <3e8cbf5e$1@news.povray.org>
That's a nice pat answer.
However, I ran his code on the Windows 3.5 version, and the only warning
message was "no pigment type given'
Personally, I fail to see how that will help the OP.
Alan Walkington
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3e6a0ac0$1@news.povray.org...
wrong
> and how to fix it.
>     Thorsten
> Thorsten Froehlich
Date: 22 Apr 2003 15:29:36
Message: <3ea59820@news.povray.org>
In article <3e8cbf5e$1@news.povray.org> , "Alan Walkington"
Well, if you cannot read, that is your problem.  Everybody else who
responded had no problem seeing the message.
    Thorsten
Thorsten Froehlich
