Subject: Variable-Programming
Date: 24 Jan 2003 15:16:45
Message: <3e319f2d@news.povray.org>
I remember a thread dealing with this item, but i can`t find it.
So I would like to ask:
How can I check the value of a variable defined in povray via #declare and
calculated in a #while loop?
I need it to check wether my boundary conditions are correct or not...
Help is very appreciated,
Robert
Subject: Re: Variable-Programming
Date: 24 Jan 2003 15:35:26
Message: <3e31a38e@news.povray.org>
#debug in the user documentation has an example on how to get a value
printed during parsing if you use the "Warning" part of it. Another thing
you could do is write the value out to a file using #fopen and #write
ross
Robert <rgu### [at] exmailde> wrote in message
news:3e319f2d@news.povray.org...
> I remember a thread dealing with this item, but i can`t find it.> So I would like to ask:>> How can I check the value of a variable defined in povray via #declare and> calculated in a #while loop?> I need it to check wether my boundary conditions are correct or not...>> Help is very appreciated,>> Robert>>
Date: 24 Jan 2003 16:54:47
Message: <3e31b627@news.povray.org>
Thanks for the quick help!!
I`ll try it out.
Robert
"Ross Litscher" <lit### [at] osuedu> schrieb im Newsbeitrag
news:3e31a38e@news.povray.org...
> #debug in the user documentation has an example on how to get a value> printed during parsing if you use the "Warning" part of it. Another thing> you could do is write the value out to a file using #fopen and #write>> ross>
