POV-Ray : Newsgroups : povray.newusers : Is there any software to import AUTOCAD files/objects into POV-RAY ? Server Time
21 Mar 2026 19:50:03 EDT (-0400)
  Is there any software to import AUTOCAD files/objects into POV-RAY ? (Message 1 to 3 of 3)
Subject: Is there any software to import AUTOCAD files/objects into POV-RAY ?
Date: 21 Jan 2003 14:38:10
Message: <3e2da1a2$1@news.povray.org>
    I am using an electronic CAD package which produces POV-ray renderings o
poplulated boards. However, the library of component models (resistors,
capacitors, connectors) is limited. The good news is that many connector
manufacturers offer online Autocad drawings. Is there any way (tool, utility,
software etc.) of converting the Autocad drawing into a POV-RAY object ?
Thanks
Joe
Version: 6.0.438 / Virus Database: 246 - Release Date: 07/01/2003
Subject: Re: Is there any software to import AUTOCAD files/objects into POV-RAY ?
Date: 21 Jan 2003 15:58:56
Message: <3e2db490@news.povray.org>
If it's not listed here, then it probably doesn't exist:
http://www.povray.org/resources/links/3D_Programs/Conversion_Utilities/
Subject: RE: Is there any software to import AUTOCAD files/objects into POV-RAY ?
Date: 24 Jan 2003 13:40:08
Message: <3e318888@news.povray.org>
3e2da1a2$1@news.povray.org...
> Hi,
o
utility,
Have you tried this?
http://autocad2pov.povray.co.uk/index.html
Hope this helps.
Bye
Txemi Jendrix
http://www.txemijendrix.com
