![](/i/fill.gif) |
"S McAvoy" <mca### [at] aol com> wrote in message
news:3e2d3736.72056892@news.povray.org...
> On Mon, 20 Jan 2003 11:24:41 -0600, "hughes, b." <omn### [at] charter net>
wrote:
> Bob, Thanks for your trouble. The problem seems to be that I am using an
ini
> file generated by Moray and it automatically generates the line
> "Pre_Frame_Return= I". If I change it to "Pre_Frame_Return= " the pre
frame
> command is run. This has nothing to do with my exe file (I think/hope) as
when
> the pre frame command= cmd.exe /k and "Pre_Frame_Return= X" the cmd.exe is
not
> run.
> BTW I do not need to use "cmd.exe /c C:\Myfile.exe" just c:\ Myfile.exe
Was your trouble, not mine ;-)
Must be a Windows program then, huh? Thought you had a DOS utility kind of
thing there.
![](/i/fill.gif) |
![](/i/fill.gif) |
On Tue, 21 Jan 2003 17:16:24 -0600, "hughes, b." <omn### [at] charter net> wrote:
It certainly was :-)
>thing there.
It is DOS, a compiled Qbasic program.
Again thanks for all your time and support
Regards
![](/i/fill.gif) |
