POV-Ray : Newsgroups : povray.newusers : I/O Macro problem Server Time
18 Jan 2026 12:22:13 EST (-0500)
  I/O Macro problem (Message 1 to 3 of 3)
Subject: I/O Macro problem
Date: 25 Dec 2002 17:43:34
Message: <3e0a3471.38883090@news.povray.org>
I am trying to write a macro that will read a file into an array. It
works when it is called the first time but when it is called a second
time I get this error.
                        #read (ReadFile <----ERROR
Parse Error: Expected 'file identifier', undeclared identifier
'ReadFile' found instead
What have I done wrong? I get no clues from the documentation and
looking at Tim Nikias Wenclawiak's io_macs.inc does not help me I am
obviously missing something. A sandwich short of a picnic maybe :
I hope it allowable to post the code here
#macro ReadDat (File_Name, Buff_Name)
#fopen ReadFile File_Name  read
#read (ReadFile,Var1,Var2,Var3)
#declare Buff_Name=array [Var1][Var2]      ;
#local H1=0                                   ;
        #while (H1< Var2 )
        #local W1=0   ;
                #while (W1< Var1)
                        #read (ReadFile,Var4)
                        #declare Buff_Name  [W1][H1]  =  Var4      ;
             #local W1=W1+1           ;
        #local H1=H1+1                    ;
#fclose ReadFile
// First call of Macro
#declare File_Name = "b.dat"            ;
#declare Buff_Name= "BufferLast"           ;
// Second call of Macro
#declare File_Name = "a.dat"            ;
#declare Buff_Name= "BufferCur"           ;
Subject: Re: I/O Macro problem
Date: 26 Dec 2002 08:44:10
Message: <3e0b07aa@news.povray.org>
1. I don't know why you're loading Var3...
2. Always use #local instead of #declare in Macros,
 unless you really want to declare something
And then, I'm not sure if the way how you pass the identifier
for the name of the array to the macro works. You're
passing a string and want it to become an identifier, if
I'm not mistaken, that doesn't work, which is the
reason why I made my macros the way I did. I had to
either declare the array beforehand, or prepare an
array-identifier which I overwrite inside the macro, like
this:
#declare Array= array[1][1]
#macro Overwrite(Array)
 #declare Array = Array[4][5] //Loaded values
I've had several cases where POV issues an error, which is actually
just a result of some other mistake, but POV can only see the actual
mistake which hinders it to parse/render, so that's not a bug.
Take a closer look at the Documentation about #declare, #local,
#macro, strings/floats/arrays. You should find some answers there.
Tim
Tim Nikias
Email: Tim### [at] gmxde
> Stephen
> #local H1=0                                   ;
>         #while (H1< Var2 )
>         #local W1=0   ;
>                 #while (W1< Var1)
>              #local W1=W1+1           ;
>                 #end
>         #local H1=H1+1                    ;
>         #end
> #fclose ReadFile
> #end
Date: 26 Dec 2002 13:53:37
Message: <3e0b4ef3.111205414@news.povray.org>
On Thu, 26 Dec 2002 14:45:35 +0100, "Tim Nikias" <tim### [at] gmxde>
How right you were. The "other mistake" was not having the second data
file in the correct format i.e. spaces instead of commas as
separators.
Thanks Stephen
