POV-Ray : Newsgroups : povray.newusers : Outline of a bicubic patch? Server Time
18 Jan 2026 12:22:13 EST (-0500)
  Outline of a bicubic patch? (Message 1 to 7 of 7)
Subject: Outline of a bicubic patch?
Date: 7 Dec 2002 13:08:49
Message: <3df23931@news.povray.org>
This may be the wrong news group for this but is it possible? I mean ok I've
got a bicubic patch object but I just want a hollow outline of the shape
rather than a solid is it possible to render this or am I barking up the
wrong tree here?
Subject: Re: Outline of a bicubic patch?
Date: 7 Dec 2002 13:26:06
Message: <3DF23DA3.4CE48431@pacbell.net>
> wrong tree here?
Do you mean something like a wireframe view of the object?
Ken Tyler
Date: 7 Dec 2002 13:50:50
Message: <chrishuff-0BCB6E.13474607122002@netplex.aussie.org>
In article <3df23931@news.povray.org>,
> wrong tree here?
It is not possible. POV does not know about the "outline" of the object,
only about ray intersections with it. There are a couple things you
could do:
The MegaPOV unofficial version had a post-process feature with a
find_edges filter, you could use that to mark pixels on or near an edge.
MegaPOV is pretty out of date though.
Somewhere in the scene file groups on this server is a scene which used
functions to do the same thing in POV 3.5.
You could give the object a pure white texture with ambient 1 in the
texture, and use a pure black background. Then render with antialiasing,
and use an image editor to select the background and fill it with white.
The antialiased outlines won't match the background color, so they will
be left behind (if your fill command has a threshold, set it to 0).
You could then use the threshold command to make the outline pure black,
and you have a black outline of the object on a white background. You
could blur the image first to make the lines thicker, this may be
necessary to get a solid line, and could also avoid the need for
antialiasing.
http://tag.povray.org/
Date: 7 Dec 2002 23:04:15
Message: <3df2c4bf@news.povray.org>
No Just the outline. In this case it's a 2d-ish image (at least it is from
the perspective of the viewer) I'm just wanting the outline of the shape
rather than a solid shape.
Date: 7 Dec 2002 23:07:23
Message: <3df2c57b@news.povray.org>
> could do:
Hmmm.... if I can't get away with a solid object I might try something like
that. But this method and the one below seem a bit more work than I want to
put in to what I'm doing at the moment. Though this particular one doesn't
seem to too bad. And if I want a coloured outline could I render the object
with color x and ambient 1 and do the same thing?
> antialiasing.
Threshold command? Is this in povray or in some image editor? And would I
blur in povray or my image editor ?
Date: 8 Dec 2002 15:19:08
Message: <chrishuff-FE492A.15160708122002@netplex.aussie.org>
In article <3df2c57b@news.povray.org>,
If you want a different color with this method, your best bet is to just
modify the final outline image. Once you have a solid black outline,
modifying to be a different color should be easy.
It's a common filter in image editors. You'd do the blurring in an
editor as well. The idea is that you start out with an image that is
white where the object is and black everywhere else, then blur it to get
"in-between" areas at the boundaries. Then you replace the black with
white (or the other way around), and use a threshold filter to make the
edge area solid.
You could do it in POV, but it takes more work. If you give us some more
information on what you are trying to do, we might be able to suggest a
better way.
Date: 9 Dec 2002 14:37:57
Message: <3df4f115@news.povray.org>
"The "D"" <dav### [at] gmxnet> wrote in message
news:3df23931@news.povray.org...
I've
> wrong tree here?
At least in some cases a hollow outline
of  the bicubic patch object is defined by its four border curves.
In this case you can build an outline object easily with pov,
since these curves are defined directly by patch control points.
Gleb
