POV-Ray : Newsgroups : povray.newusers : bicubic patch Server Time
18 Sep 2025 23:58:58 EDT (-0400)
  bicubic patch (Message 1 to 8 of 8)
Subject: bicubic patch
Date: 22 Nov 2002 07:02:54
Message: <3dde1cee@news.povray.org>
Is it also possible to create a bicubic with more than 16 points? If it is,
please give an example, because I'm a real beginner.
Thanks
Subject: Re: bicubic patch
Date: 22 Nov 2002 09:28:50
Message: <bofstu0g0rfk135gsac3klu97bgf9hm2uf@4ax.com>
On Fri, 22 Nov 2002 13:02:49 +0100, "J Tellings"
No, it is not. You have to use several patches to do that.
Peter Popov ICQ : 15002700
Date: 22 Nov 2002 14:50:36
Message: <3dde8a8b@news.povray.org>
  Your answer is technically correct, but a more helpful answer would have
been an explanation about how to use several bicubic patches to form a
larger surface with more control points. (The only problem is, naturally,
how to join patches seamlessly.)
  Perhaps I'll make a povQ&T entry about this...
Date: 22 Nov 2002 15:25:58
Message: <8l4ttuob8cfhv65724gkhutbp8012gvigg@4ax.com>
I know, but it was the only time I could give in the time I had :)
Pray do so, this one will be a helper I'm sure.
Date: 22 Nov 2002 16:47:32
Message: <Xns92CEE8BD96771seed7@povray.org>
If "3.4.5  Bicubic Patch Object" in combination with the last section of
"3.4.1.1  Understanding The Concept of Splines" is not clear in this
regard, please tell me how to improve it.
Ingo
Date: 23 Nov 2002 03:32:25
Message: <3ddf3d19@news.povray.org>
  Actually I didn't remember that tutorial. It's exactly the answer.
Date: 25 Nov 2002 21:05:14
Message: <3DE2D4D1.9040006@global2000.net>
Could a 2d equation be created for the patches?  Then to get them to
join seamlessly would just need the same tangent planes at the patches'
overlapping points.  Or would the control points need to be figured out
from equations that we make up ourselves?
Brendan
Date: 26 Nov 2002 04:32:24
Message: <3de33fa7@news.povray.org>
  Joining bicubic patches seamlessly is easier than it may sound. See the
tutorials in the POV-Ray documentation referenced by Ingo.
