POV-Ray : Newsgroups : povray.newusers : text on a cylinder Server Time
23 Dec 2025 04:54:18 EST (-0500)
  text on a cylinder (Message 1 to 10 of 20)
Subject: text on a cylinder
Date: 3 Nov 2002 06:38:49
Message: <3dc50ac9@news.povray.org>
Hello,
I want to make a text on a cylinder. Does anyone know a script to do this?
Thanks a lot!
Subject: Re: text on a cylinder
Date: 3 Nov 2002 10:56:23
Message: <3dc54726@news.povray.org>
  Read the documentation about the object pattern and cylindrical warp.
That should get you started.
Date: 3 Nov 2002 12:54:39
Message: <3dc562df$1@news.povray.org>
news:3dc54726@news.povray.org...
this?
M()}}
Warp -
I'm very sorry but your macro doesn't work. I want to make a text-object
(3D-text) on a cylinder.
Thanks!!
Date: 3 Nov 2002 13:19:26
Message: <3dc568ae$1@news.povray.org>
J Tellings schrieb:
> Hello,
> this?
I have no script. But i did this as follows:
1. create your cylinder
2. create a second cylinder with r=r1+0.0001
3. create your text on the right position
4. put your text and the cylinder from 2. together
   with intersection{}
http://www.matwei.de
Date: 3 Nov 2002 14:46:23
Message: <3dc57d0f@news.povray.org>
news:3dc568ae$1@news.povray.org...
> J Tellings schrieb:
> > Hello,
> > this?
>    with intersection{}
Thanks, this is a good and easy solution.
Date: 3 Nov 2002 14:46:55
Message: <3dc57d2f@news.povray.org>
this?
M()}}
Warp -
Thanks, but ive already got the solution from anyone else.
Date: 3 Nov 2002 17:05:19
Message: <3dc59d9f@news.povray.org>
  Uh? Which macro?
Date: 3 Nov 2002 17:05:55
Message: <3dc59dc3@news.povray.org>
>    with intersection{}
  This will not bend the text, so it will not work.
Date: 3 Nov 2002 17:06:58
Message: <3dc59e01@news.povray.org>
  Just believe me: What you want is to make an object pattern with the
text object and then apply a cylindrical warp to it.
  The other solution will not bend the text. This will.
Date: 3 Nov 2002 17:52:33
Message: <3DC5A8CE.6060703@netscape.net>
>   Uh? Which macro?
I suspect J Tellings thought your signature was the solution to his/her
problem. Some newsreaders probably don't make the signature stand out
as something separate from the body of the message. I'm only guessing
though.
-Roz
