POV-Ray : Newsgroups : povray.newusers : media density Server Time
10 Apr 2026 14:26:10 EDT (-0400)
  media density (Message 1 to 8 of 8)
Subject: media density
Date: 17 Sep 2002 09:07:01
Message: <3d8728f5$1@news.povray.org>
Is density clipped?
I'm having trouble getting really thick media using a density function which
might be explained if density is getting clipped to 1.
#macro A(V,B,C,R)#while(B-256)#if(V-128/B>=0)sphere{0,.5translate<C-4R-1,9>
pigment{rgb<1-C/8R/2C/8>}}#local V=V-128/B;#end#local B=B*2;#local C=C+1;#
end#end A(234,1,0,2)A(85,1,0,1)A(81,1,0,0)light_source{-5 1}//Tom Melly
Subject: Re: media density
Date: 17 Sep 2002 09:20:51
Message: <3d872c33@news.povray.org>
Tom Melly <tom### [at] tomandlucouk> wrote:
> Is density clipped?
  I wouldn't be very surprised if it is.
  I think POV-Ray clips values to the 0-1 range in some places where it
really shouldn't (as we can see from the transmit/filter fix, where this
clipping was removed).
Date: 17 Sep 2002 09:32:15
Message: <3d872edf$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3d872c33@news.povray.org...
> > Is density clipped?
I could be wrong, but I think that I can confirm that it is clipped. At least,
when I rewrite my function to assume it is clipped at 1, everything starts
behaving as I expect....
I don't really have any strong feelings either way about clipping on density,
but, if it is clipped, it would be nice if it was clearly documented.
(well, it would stop me trying to write functions like:
density_function = function(x,y,z){min(1,x*x+z*z)})
Date: 17 Sep 2002 09:47:08
Message: <3d87325c$1@news.povray.org>
It isn't clipped. In my experience, using higher
values amplified the effect, which is what I'd
expect it to do. But I'm not too sure about the
way you use your media, perhaps scattering
has some side-effects due to extinction?
Tim Nikias
Email: Tim### [at] gmxde
> Is density clipped?
which
Date: 17 Sep 2002 09:52:59
Message: <3d8733bb@news.povray.org>
"Tim Nikias" <tim### [at] gmxde> wrote in message
news:3d87325c$1@news.povray.org...
Quite possibly - I'll try and put a test scene together...
Whatever's happening, assuming it's clipped seems to resolve the problem.
Date: 17 Sep 2002 10:03:19
Message: <chrishuff-CC56FE.10013317092002@netplex.aussie.org>
In article <3d8728f5$1@news.povray.org>,
 "Tom Melly" <tom### [at] tomandlucouk> wrote:
> Is density clipped?
Density values aren't clipped, but function patterns are. If your
function goes out of the [0, 1] range it will be clipped, if your color
values go out of that range nothing unexpected will happen. Scale your
function values down with a multiplier and increase the color values to
compensate.
It would be nice if patterns were unclipped by default or if there was a
way to specify "no_waveform" or similar to turn clipping off.
http://tag.povray.org/
Date: 17 Sep 2002 10:14:01
Message: <3d8738a9$1@news.povray.org>
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
> compensate.
Aha! Thanks for the info.
My solution is/was pretty similiar to your suggestion:
#declare dens_func = function(x,y,z){max( med_fact, pow(x/cont_rad,2) +
pow(z/cont_rad,2) )}
(where cont_rad is the radius of the spherical media container and med_fact is
the lowest value I want used - then all I had to do was increase the intensity
of the media colour and lower med_fact until I got the effect I wanted)
Date: 17 Sep 2002 11:11:57
Message: <3d87463d@news.povray.org>
I agree.
I added 'unclipping' option in the density_file patch.
http://staff.aist.go.jp/r-suzuki/e/povray/iso/df_body.htm
In case of the current patch, one can use unclipped function
patterns as following.
#declare D3D= pattern{
    density_file function 100, 100, 100 {func(x,y,z)}
    interpolate 11 // or 10 or 12
But "no_waveform" keyword would be better way.
I am now planning to add it in the future patch.
R. Suzuki
