POV-Ray : Newsgroups : povray.newusers : hi I donot know what I am doing wrong please help Server Time
19 Sep 2025 08:47:27 EDT (-0400)
  hi I donot know what I am doing wrong please help (Message 1 to 3 of 3)
Subject: hi I donot know what I am doing wrong please help
Date: 6 Aug 2002 14:39:08
Message: <3d5017cc$1@news.povray.org>
hi
I get the following error message
Creating bounding slabs.
Scene contains 11 frame level objects; 1 infinite.
Creating light buffers.File Init Error: I/O restriction prohibits write
access to file
'/fac3/sanjay/pov/share/povray-3.5/scenes/qtvr/qtvrpanorama.png'.
Refer to the platform specific documentation for details.
also I have a .povray.conf file that contains
[File I/O Security]
None
The program parses the create a scene however cannot write the png as above
my povray.conf file is above
could any body please mail me the solution or other mail archives I will go
through them. als what are the other parameters that I can set up in
povray.conf
I am a sys adm i have set this up for a course work any advice is helpful
thanks
sanjay
Subject: Re: hi I donot know what I am doing wrong please help
Date: 6 Aug 2002 16:50:26
Message: <sgd0luopckma3pms55o4ink56lckqjtpog@4ax.com>
I was shocked to hear Sanjay Chitte say:
>access to file
you need to add a path to your 'Permitted Output Paths' in
pvengine.ini, or set 'Options' -> 'Script I/O Restrictions' to None
You may also need to make sure that write privileges on that directory
since it appears that you are sending output to a shared network
directory.
It could be any or all of these.  Check your docs under in section 1.4
under I/O restrictions for specifics.
- Tim
Date: 7 Aug 2002 01:44:48
Message: <slrnal1cuk.4sh.ron.parker@fwi.com>
>>access to file
He's using a Unix build.  There's no such thing.
I think the "none" is case-sensitive.  Try a lowercase N.  Failing that,
come over to povray.unix and ask again.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
