POV-Ray : Newsgroups : povray.newusers : hi help required Server Time
22 Mar 2026 02:34:52 EDT (-0400)
  hi help required (Message 1 to 2 of 2)
Subject: hi help required
Date: 2 Aug 2002 14:46:26
Message: <3d4ad382$1@news.povray.org>
I have compiled the povray version 3.5 on solaris 8.0 and gcc
however I get the following message when I run it on one of the scences that
are bundled with povray
the ini file is in the current directory
davinci# /apps1/prov/bin/povray noise_generator.pov
Persistence of Vision(tm) Ray Tracer Version 3.5 Unix (.Linux.gcc)
  This is an unofficial version compiled by:
   FILL IN NAME HERE.........................
   The POV-Ray Team(tm) is not responsible for supporting this version.
Copyright 1991-2002 POV-Ray Team(tm)
INI File Error: I/O restriction prohibits read access to file
'./povray.ini'.
Refer to the platform specific documentation for details.
the ini file is as follows
; Width of image in pixels.  Accepts integer values.
Width = 320
; Height of image in pixels.  Accepts integer values.
Height = 240
; Sets minimum number of objects before auto bounding kicks in.
Bounding_Threshold = 3
; Turn display on
Display=On
; Turn verbose mode on
Verbose=On
; Specify path to search for any files not found in current
; directory.  Up to 10 such paths may be specified.
; These were added by the install process with your installation
; drive and directory already patched in.
;; Search path for #include source files or command line ini files not
;; found in the current directory.  New directories are added to the
;; search path, up to a maximum of 25.
;Library_Path=/apps1/prov/share/povray-3.5
;Library_Path=/apps1/prov/lib/povray-3.5/include
Library_Path=/apps1/prov/share/povray-3.5/include
;; File output type control.
;;     T    Uncompressed Targa-24
;;     C    Compressed Targa-24
;;     P    UNIX PPM
;;     N    PNG (8-bits per colour RGB)
;;     Nc   PNG (c'' bit per colour RGB where 5 <= c <= 16)
any help is appreciated
thanks
Sanjay
Subject: Re: hi help required
Date: 2 Aug 2002 17:34:04
Message: <3d4afacb@news.povray.org>
See the povray.unix group:
 http://news.povray.org/povray.unix/26080/
http://objects.povworld.org - the POV-Ray Objects Collection
