POV-Ray : Newsgroups : povray.newusers : Underwater lights? Server Time
22 Mar 2026 02:34:46 EDT (-0400)
  Underwater lights? (Message 1 to 3 of 3)
Subject: Underwater lights?
Date: 30 Jul 2002 23:59:26
Message: <3d47609e$1@news.povray.org>
How can I make water showthe effects of a colored light?  i.e. fancy
fountains and such.  If I want to change the surface of the water I use a
plane just below it to show the light, but how do you make it show up on
water drops?
Subject: Re: Underwater lights?
Date: 31 Jul 2002 04:45:07
Message: <slrnakf8r4.bu1.steve@zeropps.org.uk>
> water drops?
How about photons? Or the way I'd probably go about it is use a colour map
on the water and give the finish a high ambient setting.
Hope some of that helps.
                                             or http://start.at/zero-pps
  9:43am  up 33 days, 20:04,  1 user,  load average: 1.01, 1.06, 1.02
Date: 31 Jul 2002 12:18:06
Message: <chrishuff-333005.11100731072002@netplex.aussie.org>
In article <3d47609e$1@news.povray.org>,
> water drops?
Well, what you are usually seeing is highlights on the surface of the
water and refracted images of the light source. Make a high ambient
shape as the light source's look_like object, give the water some
specular highlight and make sure the refraction is right and the
max_trace level is high enough. If you still aren't satisfied, you could
put an emitting media in the water to make the water itself glow. Or
maybe scattering media if you have multiple colors of light sources.
