POV-Ray : Newsgroups : povray.newusers : Testing Command Line Options Server Time
10 Apr 2026 17:50:17 EDT (-0400)
  Testing Command Line Options (Message 1 to 7 of 7)
Subject: Testing Command Line Options
Date: 24 Jul 2002 15:32:40
Message: <3d3f00d8@news.povray.org>
Is there a way to determine what quality setting is being used to render an
image?  I'd like to be able to test it and if it is below 5 replace some
slow rendering Function surfaces with simple objects.
In a related question, I'm using a parametric surface which renderd very
slowly does anyone have any suggestions on how to optimize the process?
JFMILLER
Subject: Re: Testing Command Line Options
Date: 24 Jul 2002 17:07:01
Message: <chrishuff-D44EE1.15595224072002@netplex.aussie.org>
In article <3d3f00d8@news.povray.org>,
No. You could do something very similar by just declaring a variable at
the beginning of the scene file though.
Write some code to generate a mesh from the parametric equations. The
mesh will render much faster than the parametric object, but will parse
much more slowly, and you might have faceting problems if you use too
low-res of a mesh. There is an include file somewhere called
parametric.inc that does this.
Date: 24 Jul 2002 17:20:15
Message: <3d3f1a0f@news.povray.org>
> low-res of a mesh.
  On the other hand, you can save the mesh to a file to reuse it later.
Date: 25 Jul 2002 08:59:54
Message: <Xns92569936B2CBCseed7@povray.org>
in news:chr### [at] netplexaussieorg Christopher
http://members.home.nl/seedseven/
Ingo
Date: 25 Jul 2002 09:52:05
Message: <3d400285@news.povray.org>
an
Or you duplicate the value in a variable, using the Declare constant
argument (5.2.3.1  Constant).
Philippe Lhoste (Paris -- France)
Professional programmer and amateur artist
http://jove.prohosting.com/~philho/
Date: 25 Jul 2002 17:19:59
Message: <3d406b7f$1@news.povray.org>
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
an
I have this already, but I keep forgetting to reset it.  I was hoping to be
able to automate the process.  Is there any way to pass information from an
the commandline or .ini file to the file being rendered?
Thanks for the help.
JFMILLER
Date: 25 Jul 2002 20:26:21
Message: <3d40972d@news.povray.org>
  See the section 5.2.3.1 of the POV-Ray documentation.
