POV-Ray : Newsgroups : povray.newusers : vaxis_rotate Server Time
12 Nov 2026 10:16:59 EST (-0500)
  vaxis_rotate (Message 11 to 15 of 15)
<<< Previous 10 Messages Goto Initial 15 Messages
Subject: Re: vaxis_rotate
Date: 17 Jul 2002 12:29:30
Message: <3d359b6a$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3d359a2b@news.povray.org...
>   On the other hand, it would sometimes be useful to be able to rotate
> a point/object around an axis *not* going through the origin. Is there
> a standard macro for this?
Ooo, great minds think alike!
(now, who else can I insult?).
Date: 17 Jul 2002 13:01:31
Message: <3d35a2eb@news.povray.org>
> Okay, how about someone writes a nice vaxis_rotate_extra(A,B,C,D)
function
> where A is the point to rotate, around an axis defined by B and C, and D
being
> the amount. I suspect that this is what Rob B-B wanted....
#macro vaxis_rotate_extra(A,B,C,D)
  (B+vaxis_rotate(A-B,C-B,D))
-tgq
Date: 17 Jul 2002 13:13:55
Message: <chrishuff-EF7684.12084417072002@netplex.aussie.org>
In article <3d359a2b@news.povray.org>, Warp <war### [at] tagpovrayorg>
Well, it isn't hard, just:
Orig + vaxis_rotate(Pt - Orig, Axis, Amt)
Since there is a Rotate_Around_Trans() macro and an Axis_Rotate_Trans()
macro, I guess a Axis_Rotate_Around_Trans() macro wouldn't be out of
place, though I'm not sure how useful it would be. How about:
#macro Axis_Rotate_Around_Trans(Orig, Axis, Amt)
    transform {
        translate -Orig
        Axis_Rotate_Trans(Axis, Amt)
        translate Orig
Date: 17 Jul 2002 16:33:05
Message: <3d35d481@news.povray.org>
  I was thinking more in the lines of "rotate around the axis which goes
through these two points". However, it's rather easy to modify that
expression to do that.
Date: 17 Jul 2002 19:43:33
Message: <chrishuff-6BF804.18382317072002@netplex.aussie.org>
In article <3d35d481@news.povray.org>, Warp <war### [at] tagpovrayorg>
Ax1 + vaxis_rotate(Pt - Ax1, Ax2 - Ax1, Amt)
I prefer a point and direction, because it more clearly specifies the
direction of the axis. With two points, the direction depends on the
order of the end point vectors, which is workable but possibly more
confusing. Also, I was making it similar as possible to the
vaxis_rotate() function.
