POV-Ray : Newsgroups : povray.newusers : Coincidence serface problem Server Time
21 Nov 2025 20:03:43 EST (-0500)
  Coincidence serface problem (Message 1 to 6 of 6)
Subject: Coincidence serface problem
Date: 15 Jul 2002 21:33:43
Message: <3d3377f7@news.povray.org>
Hi, I seem to be getting Coincidence serface
 problem with an object and a difference.
The cylinder is leaving traces behind at the rotation of 230, but if
rotated at 270 then the traces disapear, at 210 they are there, but less
visiable.
Any pointers to whats happening?
#local drive = union
	difference
		lathe
			cubic_spline
			11 <0,0>,<4,0>,<6,1>,<7.3,4>,<7,5.7>,<6,6.3>,<7,7.2>,<5,8>,<4,7>,<4,0>,<0,0>
			texture
				Cowling
			rotate <0,0,-90>
		cylinder
			<1,0,0> <7,0,0> 4.35
			texture
				PropGear
	torus
		6.6,0.7
		rotate <0,0,90>
		translate <6.3,0,0>
		texture
			MountRings
#declare deep1 = union
	object {drive rotate <0,-230,0>}
Subject: Re: Coincidence serface problem
Date: 15 Jul 2002 22:20:06
Message: <3d3382d6$1@news.povray.org>
Try adding the keyword sturm to end of lathe and see if that helps.
Date: 16 Jul 2002 00:25:06
Message: <3d33a022@news.povray.org>
Yes, it did thanks.  Any enlightenment following?
Date: 16 Jul 2002 00:28:24
Message: <3d33a0e8@news.povray.org>
The docs with 3.5 say this for Sturm
lathe (only with quadratic splines)
So now I have an Idea why it works, are the docs wrong here?
Date: 16 Jul 2002 02:07:48
Message: <3d33b834@news.povray.org>
"Rob Brown-Bayliss" <rob### [at] zoismorg> wrote in message
news:3d33a0e8@news.povray.org...
Oh? Hmmm. Well I only knew it wasn't applicable to the linear spline.
Date: 16 Jul 2002 09:33:02
Message: <3d34208e@news.povray.org>
  The 'sturm' keyword turns on the sturmian root solver algorithm, which is
slightly slower than the default algorithm, but gives a more accurate result.
With higher order polynomials the mathematically correct result can't be
calculated (I think that a polynomial of order 4 is the largest which has
a well-defined unique solution formula). For higher order polynomials some
approximation algorithm has to be used.
  That's about everything I know about 'sturm'.
