POV-Ray : Newsgroups : povray.newusers : having trouble with a filtered transparency... Server Time
12 Jul 2026 20:07:14 EDT (-0400)
  having trouble with a filtered transparency... (Message 1 to 5 of 5)
Subject: having trouble with a filtered transparency...
Date: 27 Jun 2002 23:46:43
Message: <3d1bdc23@news.povray.org>
Help!
In my current POVray work, I'm incorporating a lightning bolt - to do this
I'm using a GIF image textured onto a very thin box primitive, and using
'transmit' to filter out the various shades..the trouble is, the colours
that need to be completely transparent, just...well...aren't.
What happens is that I get my bright lightning bolt, fair enough...but the
part that needs to be completely transparent just looks a little darker.
I've tried pretty much everything to eliminate this problem, as you can see
from the snippet below:
#declare lightning1 = box {<0,0,0>, <2,-5,0.0001> texture {pigment
{image_map {gif "lightning1.gif" transmit 0, 0.1 transmit 1, 0.5 transmit
2,0.6 transmit 3,0.7 transmit 4,0.8 transmit 5,0.9 transmit 6,0.95 transmit
7,1.0 transmit 8,1.0 transmit 9,1.0 transmit 10, 1.0 transmit 11, 1.0
transmit 12, 1.0 transmit 13, 1.0  transmit 14, 1.0  transmit 15, 1.0
interpolate 4} scale 2.25 scale y*1.25}} interior {fade_power 0
fade_distance 0} finish {ambient 1.0  diffuse 0} hollow no_shadow}
Any help will be very much appreciated - this is making me lose a lot of
hair!!!!!!!
BTW - is there any way to compact/refine this particular piece of script?
Looks kind of ugly to me.
Tony S
Subject: Re: having trouble with a filtered transparency...
Date: 28 Jun 2002 00:30:46
Message: <VssO2CAsZ+G9Ew90@econym.demon.co.uk>
Wasn't it Tony who wrote:
>Help!
>hair!!!!!!!
It would be an awful lot easier to turn your gif into a png and give it
an alpha channel. Your code would then reduce to:
      image_map {png "lightning1.png" interpolate 4}
  no_shadow
Mike Williams
Gentleman of Leisure
Date: 29 Jun 2002 16:57:02
Message: <3d1e1f1e$1@news.povray.org>
Thanks for the help - will this also solve the transparency problem?
Tony S
Mike Williams wrote in message ...
>>Help!
see
transmit
>>hair!!!!!!!
>  texture {
>    pigment {
>  no_shadow
>Mike Williams
Date: 29 Jun 2002 23:53:03
Message: <OqQo3BAZCoH9Ew3t@econym.demon.co.uk>
I've never had any problems with transparency using png alpha channels.
There's always a slight possibility that you're doing something else
weird in your scene that I've never done that's causing the effect you
observe.
Mike Williams
Date: 30 Jun 2002 17:59:41
Message: <3d1f7f4d@news.povray.org>
Ah well - I've re-arranged the scene to show lots of detail in the
background, and this seems to have helped - the problem is still there, but
subtler now, and one would have to look pretty closely to notice any
difference.
I'll keep the PNG file format in mind though...thanks again for your help.
Tony
>observe.
>Mike Williams
