POV-Ray : Newsgroups : povray.newusers : Povray Windows Render Server Time
18 Jun 2026 20:18:34 EDT (-0400)
  Povray Windows Render (Message 1 to 2 of 2)
Subject: Povray Windows Render
Date: 25 Jun 2002 13:57:52
Message: <3d18af20@news.povray.org>
I created an still image in PovRay. The Render Window is 120 by 160 pixels
wide, when i render the scene it looks fine but as soon i switch to higher
screen size such as 320 by 340 pixels. The image in the scene becomes
distorted and messy. Would I have to change the code for the new window
size. How do i fix this problem.
Also the text casts a shadow how do i get rid of the shadow cast by the
text. In case you were wondering it is a randering of a pool ball on a green
plane.
Thanks in advance.
Subject: Re: Povray Windows Render
Date: 5 Jul 2002 05:19:31
Message: <3d2564a3$1@news.povray.org>
"maheshtd" <mah### [at] onetelnetuk> wrote in message
news:3d18af20@news.povray.org...
Standard setting of the camera are defined for a 4 (width)x3(high) ratio of
the image. To render an other ratio, you should had a
        right x*ImageWidth/ImageHeight
in your camera definition.
Remark: Pov is a really well documented software (at least the window
version I currently use), I encourage you to look inside it, it will answer
most of your questions, and while you browse the help, you will have many
(too many?) ideas for new pictures and movies. The answer to your question
can be found at
    9.1.1  Tips and tricks to achieve useful things
in the doc, I have found it using "camera" in the search menu of the doc.
green
> plane.
I don't know any solution using Pov 3.1. I think it is possible with MegaPov
0.7. It is possible with Pov3.5 adding
        no_shadow
into the text statement.
Welcome to Pov.
Chaps.
> Thanks in advance.
