POV-Ray : Newsgroups : povray.newusers : Pov-Ray Scene Help ?! Server Time
23 Dec 2025 10:07:51 EST (-0500)
  Pov-Ray Scene Help ?! (Message 1 to 4 of 4)
Subject: Pov-Ray Scene Help ?!
Date: 18 Jun 2002 08:50:24
Message: <3d0f2c90@news.povray.org>
How do i create a realistic looking moon in pov-ray. I've attempted to
re-create
the moon. But it dosen't look anything like it, it looks more like a
golfball stuck in the
middle of the canvas. I tried using image maps but these look dull and flat
and nothing
seemed to work out as i did.  When i rendered the scene in pov-ray it looked
like a 2d
object just flat.
In the pov-ray help files, it illustrates how to create the sun, for the
image i wanted to create the sun
behind the  moon sphere. When i render it the sun is nowhere to be seen .
Thanks in advance.
Subject: Re: Pov-Ray Scene Help ?!
Date: 18 Jun 2002 13:06:38
Message: <3d0f689e@news.povray.org>
maheshtd <mah### [at] onetelnetuk> wrote:
> When i rendered the scene in pov-ray it looked like a 2d
> object just flat.
  Perhaps it's just me, but when I look at the Moon in the sky, it looks
2D and flat.
Date: 18 Jun 2002 13:17:47
Message: <knqugu4m97dv6amcit1i8euoduk4eh2lr7@4ax.com>
> 2D and flat.
no face ?
ABX
Date: 18 Jun 2002 17:09:37
Message: <3d0fa191@news.povray.org>
hi,
hfsphere.pov : http://www.oyonale.com/ressources/english/sources09.htm)
// Wrapping a height field on a sphere
// (c) 2000-2001 Gilles Tran tra### [at] inapginrafr
// adapted by Norbert Kern (nor### [at] t-onlinede) to create a
realistic 3d moon
// This demo file shows an example of wrapping a height field on a sphere
// Requires POV-RAy 3.5
#include "functions.inc"
#include "textures.inc"
#include "metals.inc"
global_settings {max_trace_level 3}
  location  <0,0.5,-4>
  direction 1.5*z
  right     4/3*x
  look_at   <0,0,0>
background{color rgb 0}
light_source{<1000,1000,-1000> color rgb 1}
// First we declare a function with the map_type 1 (spherical) mapping
#declare hfmoon = function {pigment {image_map {jpeg "Moonbump" map_type 1
interpolate 2}}}
#declare rs = 0.1; // try several rs values <0.1; the lower it is the more
realistic is the effect and the more "flat" is the moon
isosurface{
        function {f_sphere(x,y,z, 1) + rs - hfmoon(x,y,z).hf*rs}
        contained_by {sphere{0,1}}
        max_gradient 20 // <--- important- adjust to your picture otherwise
strange things happen
        texture {pigment {image_map {jpeg "moonmap" map_type 1 interpolate
2}}}
        rotate y*-15
        rotate x*-20
Pov-Ray 3.5 beta is essential.
The hereby needed files MoonMap.jpg and MoonBump.jpg are from
http://snorkel.rtfm.com.au/~om/graphics/Textures/Planets%20and%20Satellites/
planets_and_satellites.htm.
Good luck
Norbert
"maheshtd" <mah### [at] onetelnetuk> schrieb im Newsbeitrag
news:3d0f2c90@news.povray.org...
> re-create
flat
> and nothing
looked
> like a 2d
> object just flat.
> Thanks in advance.
