POV-Ray : Newsgroups : povray.newusers : Using Bolts.inc Server Time
22 Mar 2026 04:19:19 EDT (-0400)
  Using Bolts.inc (Message 1 to 2 of 2)
Subject: Using Bolts.inc
Date: 24 Apr 2002 21:06:04
Message: <3cc7567c@news.povray.org>
I am very new  at using POV-RAY 3.1g. I have found bolts.inc and am having
trouble getting it to make bolts. There is no instructions on how to use it.
I have put it in #include "bolts.inc" but do not know how to get it to make
a bolt. Any help found be greatly appreciated.
Thanks in advance,
Dennis Borree
Subject: Re: Using Bolts.inc
Date: 24 Apr 2002 21:39:03
Message: <3CC75E78.7133384A@pacbell.net>
> Thanks in advance,
> Dennis Borree
Usually when you use an include file you need to find a #declared object
within that file and use it in your scene illustrated with the example
below (the name I use below may not be the name in the include file) -
object { Bolt }
If the include file does not provide a default texture or pigment then
you will need to provide one yourself -
object { Bolt texture { Bolt_Texture } }
If you can't figure it out yourself then send me a copy of the include
file via email and I will send you back a working example to get you
started.
Cheers,
Ken Tyler
