POV-Ray : Newsgroups : povray.newusers : Media and camera angle Server Time
18 Jun 2026 22:10:43 EDT (-0400)
  Media and camera angle (Message 1 to 4 of 4)
Subject: Media and camera angle
Date: 24 Mar 2002 21:30:10
Message: <3c9e8bb2$1@news.povray.org>
Based off some code I got from these groups, I've made a tornado type cloud
with media, cylindrical pattern and turbulence:
http://www.csh.rit.edu/~topher/mediacloud.jpg
However, as the angle between the cylinder and the camera increases, you can
start to see artifacts. How exactly do I get this to smooth out? Is there a
parameter like number_tests that I can increase to fix this?
Thanks in advance!
Subject: Re: Media and camera angle
Date: 24 Mar 2002 21:31:24
Message: <3c9e8bfc$1@news.povray.org>
I should probably mention this is using method 3 in POV-Ray 3.5 b14.
"Chris Becker" <cmb### [at] ritedu> wrote in message
news:3c9e8bb2$1@news.povray.org...
cloud
can
a
> Thanks in advance!
Date: 25 Mar 2002 02:16:47
Message: <3c9ecedf@news.povray.org>
cloud
can
a
That is interesting, smooth nearer top, degradation nearer bottom.
What were the 'samples' set to? And did you also use 'intervals', 'jitter',
'confidence', 'variance', etc.? Easier still, if you could just post the
media portion of your scene file that would answer all.
But basically, samples should be able to smooth it out. If the script has
intervals set to some small value though that could be the reason for this
happening I believe. v3.5 media method 3 automatically adjusts that if
intervals is left out.
sphere_sweep{b_spline 20<-2,-2,4>.1<-2,-1,4>.15<-1.5,1,4>.1<0,0,4>.1
<-2,0,4>.1<0,-1,4>.1<-2.5,-1,4>.1<-.5,-1,4>.1,<0,0,4>.1<1,-.5,4>.1
<0,-1,4>.1<-.5,-.5,4>.1<0,0,4>.1<1,-1,4>.1<1.5,-.25,4>.1<2,0,4>.1
<2,-.75,4>.1<1,-1,4>.1<1.5,1,4>.1<1.5,1,4>.1pigment{rgb 9}}//v3.5
Date: 25 Mar 2002 13:00:04
Message: <3c9f65a4@news.povray.org>
"samples" was the word I was looking for. I found the page in the
documentation which talks about samples and confidence and variance.
Thanks a bunch!
"bob h" <omn### [at] charternet> wrote in message
news:3c9ecedf@news.povray.org...
> cloud
> can
there
> a
'jitter',
