POV-Ray : Newsgroups : povray.newusers : File I/O Problems && How to test if an identifier is a Float or a vector Server Time
10 Apr 2026 21:50:03 EDT (-0400)
  File I/O Problems && How to test if an identifier is a Float or a vector (Message 1 to 6 of 6)
Subject: File I/O Problems && How to test if an identifier is a Float or a vector
Date: 14 Mar 2002 18:44:05
Message: <3c9135c5@news.povray.org>
Hi All!
All those particelsystems let me try to build my own. Therefore I need to
write vectors to a file...
Well and now, my problem: I write a bunch of vectors to a file. Later I try
to read them in again. But now I get some floats between the vectors. The
file just consists of vectors, though.
Well, I searched the problem with #debug, but I don't know wether to use vstr
or str. I have to distinguish between vectors and floats. Is there a way? I
allways get errors like
Parse Error: Attempted to redefine float identifier as vector identifier.
Or things like this. :-(
Thanks!
cukk
Subject: Re: File I/O Problems && How to test if an identifier is a Float or a vector
Date: 15 Mar 2002 04:16:18
Message: <3c91bbe2$1@news.povray.org>
vstr
> or str.
It is very simple and I hope the manual explains it:  Use vstr to turn
vectors and str to turn floats into strings.
    Thorsten
Date: 15 Mar 2002 14:49:28
Message: <slrna94k2a.ldi.ron.parker@fwi.com>
> vstr
>> or str.
That's not the question.  He has an identifier that he's just #read from
a file, but doesn't know if it's a float or a vector.
The following isn't tested, but should work.  Just replace the two #debug
statements with whatever sort of output you're seeking.
#macro ScalarOrVector( A )
  #local C = rgbft 0 + A;
  #local D = A+1;
  #local E = rgbft 0 + D;
  #if ( C.filter = C.red & E.filter = E.red)
    #debug "scalar\n"
  #else
    #debug "vector\n"
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 17 Mar 2002 08:40:17
Message: <3c949cc1$1@news.povray.org>
>     Thorsten
Well, thanks, Thorsten.
But that was not exactly my problem. I #wrote only vectors to file, but when
I #read them in again, and tried to put them in a already declared
(array-)vector-identifier, I got errors like described in the first post.
I wanted to #debug and to see the content of what I #read out of the file.
Therefore I have to convert those (strange) mix of vectors and floats to
Strings. But how can I decide wether there's a vector or a float within my
identifier. I asked if there's a method like "isNumber(<identifier>)" and
"isVector(<identifier>)"...
Then I could use str of vstr, of course.
But I decided to work around that problem, by #writing to a file and
#including this one lateron instead of #reading it. (That's the way, it's
done in the examplefile life.pov)
Thank you anyway...
Kalle
Date: 17 Mar 2002 09:01:48
Message: <3c94a1cc$1@news.povray.org>
>   #local D = A+1;
>     #debug "scalar\n"
>   #else
>     #debug "vector\n"
>   #end
> #end
Thank you Ron, I wil have a look into it.
Kalle
Subject: Sorry for the wrong month...
Date: 17 Mar 2002 09:01:49
Message: <3c94a1cd$1@news.povray.org>
I just had to start Povray 3.5 and wasn't ready to download 13 yet...
Kalle
